US Standard Gears... - JeepForum.com
post #1 of 2 Old 01-06-2014, 08:36 PM Thread Starter
poppatello
Anyone running US Standard ring n pinion? I'm looking at a set of 4:88 and they seem decent...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 2 Old 01-06-2014, 09:51 PM
lucdog
lucdog's Avatar
1980 CJ5
I'm running this brand in the GM 10 bolt in the front of my CJ 5. I haven't had any problems with these gears in 3 years of hard trail use. The gears set up with no problems, with a good pattern. When I bought the set from Randy's the tech told me these gears were a little noisy , Im only using them in the front axle with locking hubs, so noise isn't a issue.
I'm not sure if I would run them in a DD in the rear, based on what I was told.
I've only used the American Standard and Yukon gears. No issues with either. So, What I would do is Yukon in the rear, AS in the front.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
