Urgent Steering box advice !?! - JeepForum.com
post #1 of 5 Old 02-20-2002, 01:22 PM Thread Starter
Guy Hollister
Cool Urgent Steering box advice !?!
CJ7 RHD... power steering... sort of...
My steering box has been recently 'fixed' by Dave Sargent in Doncaster [don't ever go there]....
He really has fixed it good and propper because today it stopped dripping ATF and absolutely pissed it out [luckily just when i had got home].
The question is - can i still drive it DRY ? or will i be causing a bigger problem than what i believe it is at present [blown seal on the box].
If i were to top it up - it would be empty again in 1-2 mins... so that not much of an option. Plan B is - i hear you can mix 1/2 brake fluid and ATF for a wicked cocktail of "seal enlarging" gloop that may temporarily reseal it - but i doubt that would work with this one.
The thing is - i am moving house in 2 days and need it... and i dont have the time nor to get it recon'd by Friday !! Argh.
Cheers
Guy
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
post #2 of 5 Old 02-20-2002, 06:40 PM
mrclean
Post
Just take the belt off the pump and run it. There should be enough oil coating the works to run for a while. I wouldn't drive a thousand miles that way, but it will be OK for a while. Be tough to steer though, hope you ate your Wheaties!
mrclean is offline
post #3 of 5 Old 02-25-2002, 12:56 PM Thread Starter
Guy Hollister
Cool
Solved...
I hacked the steering Vbelt off ... as i didn't have the bloody time to piss about with taking all the belts off and the steering belt is at the back !
Cheers
Guy
1984 RHD CJ7
1979 LHD CJ5
post #4 of 5 Old 02-25-2002, 01:48 PM
CJ10a
Post
Now try and park it in a tight spot!!!!
CJ10a
Chevy 350 TH350 NP203
ARB's 33" BFG MT's
Custom everything and most of my life savings
CJ10a is offline
post #5 of 5 Old 02-25-2002, 01:56 PM Thread Starter
Guy Hollister
Cool
yeh phil - 3 point turns are a bit of a job !
1984 RHD CJ7
1979 LHD CJ5
Steering parts replacement advice atomicflatulenc Jeep CJ Forum 3 01-13-2010 08:10 AM
Steering Wheel Advice whizerd Jeep CJ Forum 7 03-07-2008 11:11 PM
83' CJ5 steering work, advice? scottycj5 Jeep CJ Forum 3 10-15-2007 01:29 PM
Transmission Advice Needed Urgent tucka Jeep CJ Forum 4 10-23-2005 10:03 PM
Steering Column advice Hank86 Jeep CJ Forum 0 10-29-2004 05:56 PM
