Upper rad hose problem - JeepForum.com
post #1 of 9 Old 03-02-2013, 05:32 PM Thread Starter
43Duc
1982 CJ8
I was wondering if anyone knows of anyone that sells an upper radiator hose that's pre-formed to accommodate the AC compressor. Local auto parts store only sells universal hoses for CJs. I have to use a rig of zip ties and to keep the hose out of the alternator fan.
My engine is a 4.2 w/ stock fan and radiator.
Thanks for any help!
-chris
43Duc is offline
post #2 of 9 Old 03-02-2013, 06:04 PM
BlueRubiconrich
you can cut the piece of steel on the right fitting and or move it.
Try 4WD.com
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 9 Old 03-02-2013, 06:06 PM Thread Starter
43Duc
1982 CJ8
Just to clarify; I had the pre-formed upper hose for the 1982 CJ, but that hose bend gets nicked by the fan when the Jeep and motor flex. At idle there is about 1/2" of clearance. I'm now running a universal hose that I have to pull back w/ zip-ties. That hose is leaking around the radiator due to the strain put on it by the zip-ties. I'm looking for a hose that's pre-formed to take into account the AC compressor.
Here's a photo of the original hose:
43Duc is offline
post #4 of 9 Old 03-02-2013, 06:07 PM
BlueRubiconrich
I cut and turn the fitting after this picture was taken
post #5 of 9 Old 03-02-2013, 06:09 PM
BlueRubiconrich
My yorks on top and alt below off of a 80's AMC Concord.
post #6 of 9 Old 03-02-2013, 10:17 PM
davbytrace
1979 CJ7
I may be nuts but that's looks like an alternator that is causing the problem. Just adjust the alternator position and get a different drive belt if needed.
davbytrace is offline
post #7 of 9 Old 03-03-2013, 01:02 AM Thread Starter
43Duc
1982 CJ8
You're not nuts... I mis-spoke.... it's the alternator that's mounted high to allow for the AC compressor just below.
43Duc is offline
post #8 of 9 Old 03-03-2013, 10:00 AM
CSP
With a shorter belt it looks like the alternator wouldn't be so high and close to the hose.
CSP is offline
post #9 of 9 Old 03-03-2013, 01:21 PM Thread Starter
43Duc
1982 CJ8
Just took a look and I can't lower the alternator:
It won't go any lower because of the electrical connection. I was hoping that idea would work...
43Duc is offline
