uphill stall ?! - JeepForum.com
post #1 of 7 Old 02-11-2002, 09:37 AM Thread Starter
mike mcgovern
Post uphill stall ?!
I recently had someone rebuild my carb on an 82 cj-5 and now everytime i try to climb a hill, the jeep imidiatly loads up and stalls. It runs ok on flat ground or when going down a decent, but will not climb. Could anyone help me out with what might be causing this, (stuck float?) Also, it has a hard time running at higher speeds, it runs fine with little throttle but if i put it to the floor while in 3rd or 4th gear, it loads up and doesnt accelerate, anyone have any ideas? Thanks
mike mcgovern is offline
post #2 of 7 Old 02-11-2002, 09:55 AM
MuddyCJ5
Post
I'd say it's a problem with the float. I would think it's not adjusted properly. The rebuild kit you installed should have the proper settings and procedure for doing it.
Good luck, happy trails, Dan
MuddyCJ5 is offline
post #3 of 7 Old 02-11-2002, 10:03 AM
Mackddy6
Post
maybe...........accelerator pump? not sure though...just throwing out suggestions
Josh
'75 CJ-5 360, headers, 4 barrel, full custom cage, custom body mounts. Soon to have:FSJ D44s, 36 inch Goodyear MT/Rs, custom spring mounts, SOA, 4" lift springs, 2 inch body lift
It's better to beg forgiveness than to ask permission
Mackddy6 is offline
post #4 of 7 Old 02-11-2002, 06:12 PM
MR.CJ-7
Post
I had a similar problem after a rebuild. The guy who built it for me said it would put a "4wd spring" on the float. I took it back in to him he did something because now it doesn't stall on even the steepest or bumpiest hills.
Former CJ'er
MR.CJ-7 is offline
post #5 of 7 Old 02-11-2002, 06:17 PM
Bob K
Bob K's Avatar
Post
Sounds like a poorly adjusted float level.
But I'd really like to hear more about what MR.CJ-7's mecahganic did with the spring.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #6 of 7 Old 02-13-2002, 12:52 AM
manhattanjeep
Post
MR CJ7 I also would like to know what your mechanic did to that carb.
76 CJ5
Real Jeeps are not bought, they're built!!!
manhattanjeep is offline
post #7 of 7 Old 02-13-2002, 03:38 AM
JIM79CJ7
JIM79CJ7's Avatar
Post
I would check float adjustment also , wet float test ! top of carb off , many people set them dry and dont check them wet !
"Magic Float spring" I gotta hear about this .
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
Loss of power uphill HvyDRckCrwlr Jeep CJ Forum 4 10-30-2009 11:56 AM
accelerating my jeep sputters, especially when going uphill rcawrse Jeep CJ Forum 11 10-27-2009 12:59 PM
Dies going uphill! trueprimitive Jeep CJ Forum 2 07-31-2009 08:03 PM
83 CJ7 Losing Power Uphill VikingsFan99 Jeep CJ Forum 7 06-28-2006 01:04 PM
TBI run and stall nightstalker5.0 Jeep CJ Forum 2 12-16-2004 05:51 PM
