upgrades - JeepForum.com
post #1 of 9 Old 02-02-2002, 05:19 PM Thread Starter
jp7
Post upgrades
I have a few questions if you guys can help.I have two jeeps a 77 cj-5& a 84 cj7 the 5 has a 304 with a 3 speed the 7 has a 258 with a 4 speed.1st.I'll be mostly on the street but I also plan to do moderate trail ridding in the future,I have a chance to get an 258 bored .060 with a 5 speed.Would that be a good set up with a intake,carb,and headers?also I would like to do the HEI swap or other high ignition change can someone help with the parts I need to get and what I have to do to get it done,do I get rid of the present eletronic stuff?also I,m pretty sure I'm going to keep the 7 so is there anything I should swap from the 5 before I sell it?and 1 last thing,is there somewhere I can go to get all the ad ons, swaps,up grades,etc from other vechecles?how aboat power brakes,rear disc's,stuff like that.thanks in advance from tx.
jp7 is offline
post #2 of 9 Old 02-02-2002, 07:06 PM
Bulletproofcj7
Post
I just installed a H.E.I distributer in my 304 from D.U.I ( davis unified electronics)
very easy to install. it only takes one 12 volt wire and it works great. kinda expensive though.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 9 Old 02-06-2002, 12:09 PM Thread Starter
jp7
Post
thanks,but I am looking for low budget stuff not only for the fun of it but trying to save cash for gee wiz stuff.
jp7 is offline
post #4 of 9 Old 02-06-2002, 02:16 PM
T Hoff
1975 CJ5
Post
The aftermarket stuff might be offered in 4Wheel Drive Hardware. www.4wd.com
Get the catalog it's much easier to find what you are looking for.
You dont want to swing the V8 into the CJ7?
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #5 of 9 Old 02-07-2002, 01:12 AM Thread Starter
jp7
Post
I have thought about swapping motors but I've read that it is so expensive to build up 304 that I'm shying away from it.If I did the swap would the 4 speed bolt up to to the 304 without a adapter?
jp7 is offline
post #6 of 9 Old 02-07-2002, 03:28 PM
1911shtr
Post
I have a 304 in my cj7. I really don't like it. The power output isn't very good. The 3 speed tranny doesn't help. If i were you I would go with the beefed up 258.
1911shtr is offline
post #7 of 9 Old 02-08-2002, 02:01 AM Thread Starter
jp7
Post
thanks for info
jp7 is offline
post #8 of 9 Old 02-09-2002, 06:56 PM
Jeep CJ5
Post
I have a 304 V-8 that has been professionally rebuilt. It has 9 1/2 to 1 compression,bored .30 over, a mild cam, stock: carb, intake and exhaust manifolds. The Jeep has a low restriction dual exhaust (she is loud!!)
This engine has plenty of power. I am running 33in Super Swampers with 3.73 gears and my CJ5 is very quick and powerful.
The rebuild including parts cost $2,4oo. I could only imagine how it would be with headers, an intake manifold and a 4 bbl carb.
I am a sucker for cubic inches. I always liked my Jeeps with V-8's better than the 6's.
But I would not use the three speed. The gears are just to wide. Is it the t-18 that has the ultra low first gear? Someone help me out here. (too lazy to go check in my Jeep books)
Good luck!
1974 CJ5 Renegade...restored...100% perfect
too nice to be true!!!
Jeep CJ5 is offline
post #9 of 9 Old 02-10-2002, 09:45 PM Thread Starter
jp7
Post
thanks for in put of info,sounds like a rockin jeep but the cash uot lay just stubed my bib toe!!!!!!!!!!!ohhhh
jp7 is offline
304 upgrades what would you do? DeadPhish Jeep CJ Forum 5 06-18-2009 02:15 PM
58 cj5 upgrades TheClixter Jeep CJ Forum 15 08-05-2007 01:09 PM
amc 20 upgrades TrailCJ7 Jeep CJ Forum 10 03-30-2007 07:50 AM
upgrades cityofcompton3 Jeep CJ Forum 1 09-02-2005 07:02 PM
82 CJ upgrades double8 Jeep CJ Forum 4 04-19-2004 12:30 PM
