Upgrade diesel CJ7 - JeepForum.com
post #1 of 17 Old 01-31-2011, 02:45 PM Thread Starter
calvykins
Upgrade diesel CJ7
Hi Everyone
I live in France and I own a CJ7 with a Renault diesel engine. It is particularly gutless.
Is there a more powerful diesel engine which would fit the CJ7? A Renault 2.4TD for example
Were the Renault engines on the CJ7 turbocharged?
Thanks
calvykins is offline
post #2 of 17 Old 01-31-2011, 06:07 PM
papa355
1977 CJ7
http://www.4btswaps.com/forum/showth...mmins-6BT-Swap
5.9 cummins, that's the way I'd go , brother. " have torch and welder...anything will fit"
papa355 is offline
post #3 of 17 Old 01-31-2011, 07:52 PM
Pathkiller
1974 CJ5
Forget the Cummins suggestion. If you could even find one in France it would be expensive and hard to find spare parts for, not to mention being way too heavy to be a practical Jeep engine. The 5.9L Cummins engine literally weighs as much as a bare Jeep frame and body, which would be an incredibly dumb swap.
Is your Renault the 2.1L? It was also used in Jeep XJ Cherokees between 1984-86 in the US and was turbocharged, but only rated at 85hp. The VM Motori diesel used in later export Cherokees was a 2.5L turbodiesel and had almost twice the HP and torque of the little Renault.
I don't know what Renault engine would swap for your existing engine, but I would assume the Renaults would have the same bellhousing pattern and bolt to the existing transmission.
Pathkiller is offline
post #4 of 17 Old 01-31-2011, 07:54 PM
benullman
1981 CJ7
Wouldnt it be possible just to rebuild the diesel with a little more power? It seems like the power could be there if you gave it a little more top end power.
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #5 of 17 Old 01-31-2011, 07:59 PM
jpywell52
1979 CJ7
isuzu made a lot of small displacement diesels as well. Common in troopers.
jpywell52 is offline
post #6 of 17 Old 02-01-2011, 06:51 AM
BioTex
1979 CJ7
SD-33T They were used in the CJ10-A tugs, so should bolt right in nicely.
Not a whole lot more power, but some.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #7 of 17 Old 02-01-2011, 01:55 PM
Pathkiller
1974 CJ5
And how many of them are in France? I suspect very few, if any.
post #8 of 17 Old 02-01-2011, 03:42 PM
h2ojeep
1978 CJ7
Nissan sd33 was also used in (Nissan) forklifts, so there be more in France than one would think .
What about some of the Mercedes-Benz diesels. Someone chime in that knows something about them. Would there be a lot in Europe? Would there be some that would have a good power curve?
h2ojeep is offline
post #9 of 17 Old 02-01-2011, 04:12 PM
Pathkiller
1974 CJ5
Yes, but the point is that Renault is French. So there are no doubt a lot more of Renault than any other brand. He already has a Renault diesel, so the simplest and easiest swap would be to another, more powerful, Renault.
post #10 of 17 Old 02-02-2011, 02:54 AM Thread Starter
calvykins
Is it difficult to retrofit a turbocharger to a non turbo diesel engine?
post #11 of 17 Old 02-02-2011, 03:27 AM
stgil
1982 CJ7
Hello!
From factory ...the answer is NO...
but... lot of French's people swap the regular J8S Renault 2.1L (60HP) to a turbo charged J8S Renault 2.1L (~90HP with the right setup )
But be careful:
1- There is only some turbo charged J8S which fit with the clutch (bellhousing)...
2- French's law forbid engine swapping ... in fact you can but... it's very risky:
you need to qualifiate again the car : crashtest and so on... !! (you need to build 2 cars)
There is a very little amount of CJ7 diesel turbo charged (with engine swapping) authorized by the French's administration (DRIRE) but now it is impossible...
You don't know how lucky you are American people...
Here some vintage pics of the administration granted turbo charged 2.1L Diesel J8S Renault:
To the question :
The answer is NO: or you must change the pistons, the injectors, oil pump and so on... It's easier to change the whole engine...
Regards
FULL DANA 30 REBUILD->
CJ7 LAREDO REBUILD->http://www.jeepforum.com/forum/f8/82-cj7-laredo-diesel-restoration-1179198/
stgil is offline
post #12 of 17 Old 02-19-2011, 10:27 AM
papa355
1977 CJ7
5.9 cummins will fit in anything you make it fit into. A jeep is just a square box sittings top of 4 tires. It's not a dumb swap, just may not be for him.
http://www.dieselpowermag.com/featur..._jk/index.html
The 4bt is a good jeep swap.
http://www.jeepforum.com/forum/f37/c...-diesel-52794/
duramax
http://www.jeepforum.com/forum/f8/duramax-swap-61446/
http://www.jk-forum.com/showthread.p...diesel-in-a-JK
http://www.4btswaps.com/forum/showth...-8-duramax-6.6
my point is, you can do anything you want to, whether you have the cash or not???? ( that may be an issue......) NO swap is a dumb swap, it's all about being creative. Doing something somebody told you was dumb or couldn't be done.......greatest feeling ever.
papa355 is offline
post #13 of 17 Old 03-11-2011, 06:49 PM
6.0cj7
1978 CJ7
Go find a nice powerstroke they fit good in the engine bay.
6.0cj7 is offline
post #14 of 17 Old 03-11-2011, 07:19 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Well, from stgil's post, it sounds like any Cummins, P/stroke, or Duramax swap is impossible, especially if you are not even allowed to put in an upgraded version of the same engine!
Wow, I guess those in Kalifornia shouldn't complain so much anymore...
Rick
Cutlass327 is offline
post #15 of 17 Old 03-02-2012, 06:40 AM
Dipstick
1980 CJ7
https://www.youtube.com/watch?v=Avtg...e_gdata_player I have an 80 cj7 with the peugoet diesel in it from the factory. It's only around 60 hp. It's a lot of fun but I wish it was a turbo.
Dipstick is offline
Cj5 diesel? SCOOTERMCGAVIN Jeep CJ Forum 24 12-24-2010 12:29 PM
Next step Team Rush upgrade ignition upgrade tevans59 Jeep CJ Forum 7 03-29-2010 04:39 PM
Cj Diesel NCCJ5ER Jeep CJ Forum 8 03-18-2007 09:17 AM
258 EFI upgrade & YJ spring upgrade jeepin'bo Jeep CJ Forum 2 04-08-2005 06:02 AM
'84 CJ 7 doing the diesel Nick CJ7 Jeep CJ Forum 0 03-18-2004 02:15 PM
