#1 | |
Updated Scrambler project pics
Went up to my buddy Anders' place for a few hours on Sunday. We sorted out some of the cage fit-up, seat positioning, etc and put the axles under it so we could support it more safely and move it if need be.
Main pieces of the cage awaiting my arrival: Metal Fusion Fab tube fender builder's kit: Doors & windshield frame hung for cage test-fitting: Front axle installed, stock fender installed to start fitting tube fender: Rear axle installed:
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers. '83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff. http://www.jeepskate.net |
#2 |
Sweet, what drivetrain / engine etc you throwing in there?
1982 CJ7
Iron Duke "Hurricane" 151 CID 2.5L 4-Cyl T177 Tranny | Dana 300 T-Case Dana 30 Front | AMC 20 Rear |
#3 |
Way cooool!
If I only had a garage.........and some talent! ![]()
Mark in Kentucky 93 YJ 4cyl 5 spd 4" RC Lift, 33x12.50 MT's |
#4 |
TBI'd Dodge 5.9/360, Dodge 904 auto with Jeep 999 guts & Trans-Go shift kit, Dodge NP203 range box, Advance Adapters doubler, Dana 300 with Tera 4:1 & heavy duty rear output & JB heavy duty front output, narrowed Blazer Dana 44 front with 4.10's & Electrac, semi-float Dana 60 rear with 4.10's & Detroit.
#5 |
Wow!! I've been slacking on this thread. This phase of the build-up took *much* longer than planned, but if all goes well I should be trailering it back home in a couple of weeks (I brought the rollcage home this past weekend).
Starting on the cage: Tacking in the Metal Fusion Fab tube fender kit: Re-centered HumVee wheels with Ballistic Fab rock rings: Back on all fours with Shrockworks rockers installed:
#6 |
Cutting out the wheelhouses & replacing with 'Jeep' trailer fenders:
More progress on the rear of the cage: Cage back in & starting on the front, front bumper mounted to beef the winch mount: Cage nearing completion:
#7 |
Underbelly nearing completion:
#8 |
Great job! Very impressive.
99' XJ 5.5" TREKS Y-link kit, SYE, 35" Xterrains on AR wheels with 3.75 BS, TREKS Unibody stiffeners, TREKS Rock Rails, 1-Ton OTK Steering,K&N |
#9 |
Here's the tube flare pics (fiddling with the camera settings, so they're a bit over-exposed) from Friday's session.
[img]
#10 |
GROUND POUNDER
Nice! Liking the fender work..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#11 |
love those fenders
Yellow 86 CJ-7 Red 70 CJ-5 "Out on the road, out 'neath the stars, Feelin' the breeze, passin the cars." |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
