Unlocking ignition switch w/o key - JeepForum.com
post #1 of 17 Old 12-03-2002, 06:52 PM Thread Starter
bowhunter
Does anyone know how to unlock the ignition switch in a 78 cj5? the PO didn't have a key and he never lock it. I was working on it tonight and somehow as I was getting in and out or moving around in the jeep it locked up.
bowhunter is offline
post #2 of 17 Old 12-03-2002, 07:08 PM
Mud Dobber
a lock smith can unlock that switch for you and also remove it from the column. You can then either replace the entire lock assembly or have the lock smith cut you a new key for it. Short of that you do not have many options unless you do not mind causing damage to the jeep.
Mud Dobber is offline
post #3 of 17 Old 12-03-2002, 07:45 PM Thread Starter
bowhunter
Dobber I was hoping that I could remove the steering wheel and be able to get numbers off it to have a key made or remove it and if I can remove it is there any wiring invovled?
post #4 of 17 Old 12-03-2002, 08:50 PM
werewolf7111
the complete switch with keys sells for about $16 in 4wd- its not worth a locksmith.
to remove it-- get a dent puller type of slide hammer and screw in and jerk out- it only has one plastic tab holding it in
then push the new switch assm in- youre done
Joe MSME PE
werewolf7111 is offline
post #5 of 17 Old 12-03-2002, 08:55 PM
werewolf7111
afterthought
I worked as a locksmith when i was a teen
assuming the info is still available- the VIN could be used at a dealer to cut a key and locksmiths have books to look it up and remotely cut a key( assuming its the OEM switch)
also they used to sell key ring sets( a big ring with every combination of key depths on them- you keep trying till one fits)
prehaps an older locksmith may still have some
but yanking the switch is easier for the effort
Joe MSME PE
post #6 of 17 Old 12-04-2002, 10:02 AM Thread Starter
bowhunter
Wolf would pulling the cylinder out with slide hammer damage the "plastic tab" and not let the other cylinder lock in place
post #7 of 17 Old 12-04-2002, 02:19 PM
werewolf7111
no, the plastic tab is on the lock body proper- you are gonna trash the whole thing
you wont damage the recess that the tab locks in
post #8 of 17 Old 12-04-2002, 02:26 PM Thread Starter
bowhunter
Thanks wolf. Gonna get me uh slide hammer
post #9 of 17 Old 12-05-2002, 09:24 PM
only in a jeep cj
If you don't care about your Jeep, follow the above info! If you do, remove the horn button, steering wheel, compress lock ring and remove snap ring, unscrew turn signal cam and move it to the side. There are 2 types of ignition locks used in these GM type columns. If you see a black torx bolt, unscrew it and the cylinder will pull right out. If no screw, there is a thin slot that you insert a thin metal blade and push down the above mentioned tab. Then, go up to Autozone/Carquest/PepBoys, or whatever you have in your area and get a CJ lock set....15 to 25 bucks! reverse to install...NO SLIDE HAMMER (in case you have the screw type...you will damage the inside of the column if you have this type and use a slide hammer....the tab type might work this way, but why risk it)
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 17 Old 12-06-2002, 06:17 AM
werewolf7111
granted, youre right that thats the correct by the book way- but there are plenty of short cuts with minimal risk also that work too.( some not always in line with man. recommendations either)
post #11 of 17 Old 12-06-2002, 07:33 AM Thread Starter
bowhunter
Ed thanks the more info the better.
post #12 of 17 Old 12-06-2002, 06:03 PM
only in a jeep cj
Sorry about being harsh, Werewolf. I know there are times when we want to take a slide / sledge / and all other hammers to the problem to make it go faster! I do. My favorite "by the book" procedure is when they say disconnect the positive battery cable before you do ANYTHING! Wow
Ed
1975 CJ-6 1983 CJ-8
post #13 of 17 Old 12-06-2002, 07:01 PM
werewolf7111
thats fine "only", i accept your apology and offer one of my own
to who may read these presents:
"only" was 100% correct in correcting me because i failed to consider this forum is for viewers with varying skills and resources.
yes my "way" will work and has many times- BUT it is NOT the correct method and does have a risk factor.
I have put several 'techno" posts here and have gotten dozens of emails asking for more info which I have answered( either individually or "en masse")
I am a professional engineer who DOES know the value of the book( and the reason the book was written) as well as understanding an "experienced" person can combine/circumvent/alter steps, whereas a less experienced jeeper may not be advised to.
I posted my answer here(on this key issue) from a recent issue I did( on one of my own jeeps) WITHOUT advising the readers that there is a potential for other damage. ( although minimal- still there, regardless)- after re reading and thinking- I admit- that was the wrong approach and could be viewed as misleading to the lesser experienced.
In the future, i will be more careful and list potential risks with my posts
I offer my apology for my lack of forethought and i stand corrected.
Joe MSME PE
post #14 of 17 Old 12-06-2002, 07:16 PM Thread Starter
bowhunter
CJ, Wolf glad ya'll are here. Ed doing it your way but am having trouble finding out where to stick the thin piece of metal. May have to do wolf's idea
post #15 of 17 Old 12-06-2002, 09:13 PM Thread Starter
bowhunter
Ed, Joe cylinder IS OUT. Ed your idea was working until I could not get the tab to release. So Joe did the "slide hammer thing"but with a pair of channel locks and a hammer. Didn't take much force to release. Thanks to you both
Ignition Switch bad??? Texas_CJ7 Jeep CJ Forum 8 12-01-2009 02:06 PM
Ignition switch? andyshores Jeep CJ Forum 19 07-24-2009 06:53 AM
ignition switch dirtdad Jeep CJ Forum 3 04-27-2009 08:56 PM
Bad Ignition Switch? chadcarter Jeep CJ Forum 1 11-10-2008 08:37 PM
Ignition switch ragincajunATL Jeep CJ Forum 0 04-26-2008 02:29 PM
