Unknown Sensor - JeepForum.com
post #1 of 7 Old 03-23-2013, 03:30 PM Thread Starter
Jester77
Unknown Sensor
If this is the Water Temperature Sensor,
Then what is this unknown sensor that came from this picture (the black one on the right)? When I took it out, coolant came out. It has two black electrical leads coming out of it and mine are diked off.
Any help greatly appreciated. I'd like to get it working again, whatever it is.
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
post #2 of 7 Old 03-23-2013, 04:52 PM
Patter
1981 CJ5
I believe it's the coolant temp switch.
Google. Jeep adventures under the hood.
"I have a very strict gun control policy: if there's a gun around, I want to be in control of it."
Patter is offline
post #3 of 7 Old 03-23-2013, 04:55 PM
vinnyabs
1983 CJ7
I know you can use both for a temp sender. Maybe po used it too
Earning an engineering degree one CJ7 hiccup at a time
vinnyabs is offline
post #4 of 7 Old 03-23-2013, 05:20 PM
MoC
First one if the temp sending unit and the second is the coolant temp switch.
MoC is offline
post #5 of 7 Old 03-23-2013, 05:42 PM Thread Starter
Jester77
I appreciate the info/link. I guess if you don't have an ECU, you don't need this correct?
Jester77 is offline
post #6 of 7 Old 03-23-2013, 05:47 PM
MoC
If you want to have your choke and manifold heater correctly wired the coolant temp switchr is needed.
MoC is offline
post #7 of 7 Old 03-23-2013, 07:20 PM
stamp32
I thought the choke and manifold heater where wired through the oil pressure sensor.
Chris
stamp32 is offline
