Unknown oil leak in my CJ5, any help? - JeepForum.com
post #1 of 9 Old 11-11-2013, 12:25 AM Thread Starter
Alvin05
1981 CJ5
Unknown oil leak in my 1981 CJ5
Leaking out of automatic shift gear boot.
Causes? What should I do?
Will include pictures soon.
Thank you.
Alvin05 is offline
post #2 of 9 Old 11-11-2013, 08:13 AM
holliewood61
1981 CJ7
pics would be very helpful. it sounds like it could be trans fluid leaking onto the front drive shaft and being slung up to the boot from the rotation of the shaft.
holliewood61 is offline
post #3 of 9 Old 11-11-2013, 11:05 AM
LumpyGrits
Make sure the tranny is NOT over filled.
Is this oil-gear oil, engine oil or what?
BTW, IF you are look'n for a good Jeep club to join. Check into the Roughwheelers 4 WD Club.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 9 Old 11-14-2013, 01:33 PM Thread Starter
Alvin05
1981 CJ5
thanks LumpyGrits and holliewood61
Alvin05 is offline
post #5 of 9 Old 11-14-2013, 01:39 PM
LumpyGrits
Auto. trans ????
Make sure the tranny vent is not blocked/clogged .
Check the oil level in the tranny.
Then check you t'fere case oil level.
There are seals in the shift lever housing you can check.
Get a copy of a REAL Factory Service Manual(FSM). Haynes etc doesn't cut it.
The FSM will 'walk' you through the shift lever R&R.
LG
post #6 of 9 Old 11-14-2013, 01:42 PM Thread Starter
Alvin05
1981 CJ5
thanks LumpyGrits. yes, auto. recently purchased, as is....
Alvin05 is offline
post #7 of 9 Old 11-14-2013, 01:53 PM
LumpyGrits
What was the oil level like, when you checked it?
LG
post #8 of 9 Old 11-14-2013, 04:51 PM
lucdog
lucdog's Avatar
1980 CJ5
You filled out your profile, so that's good, Unfortunately the REAL factory service manual wont help if its for a CJ, since you have a Ford engine and transmission.
I would first pull the boot and have a look . Post some pictures here of all the linkage.
Bill
LG, it's a C4 with serious modifications.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #9 of 9 Old 11-14-2013, 04:53 PM
lucdog
lucdog's Avatar
1980 CJ5
That's quite a bit of oil for a auto to leaking from the boot area.
Bill
...sorry, double post.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
