Unique Dana 20 - JeepForum.com
post #1 of 11 Old 03-22-2010, 07:18 PM Thread Starter
patduke90
Unique Dana 20
I've got an 81 scrambler. 304, t18, and a Dana 20 transfer case. I was told that the transfer case was either out of an old commando or a J-series truck since it has the J shift pattern. Is this correct? Also, is there a shift light for these? Does anybody know the correct shift pattern? I know the first position is 4wd hi, and I think the 2nd (which is over to the right) is 4wd low, but I'm not sure of the others. Any help would be appreciated...
patduke90 is offline
post #2 of 11 Old 03-22-2010, 08:26 PM
BriansCJ
1994 XJ Cherokee
I know the shift pattern of my Dana 20 is
4HI
2HI
N
(2LO)
4LO
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 11 Old 03-22-2010, 08:33 PM Thread Starter
patduke90
4HI
2HI
N
(2LO)
4LO
This transfer case has a J-shift pattern, it isn't the typical straight up and down pattern of the Dana 20
post #4 of 11 Old 03-23-2010, 01:17 AM
Trapshooter
Your CJ8 would have come stock with a Dana 300 but it sounds like the T-case was changed out at some point. Every Jeep Dana 20 I've seen is 4H, 2h, N, 4L.
You may have an early Ford Bronco unit which did have a "J" pattern from 1973-1977 which was:
4L
N 2h
4h_l
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #5 of 11 Old 03-23-2010, 09:14 AM
CSP
The FSJ and early Commando Dana 20 have a U shaped pattern, not a J shape. That would be an early Bronco pattern with a drivers side front output.
The pattern is like this (the periods are there to get neutral in the right spot):
2H 4L
.|...N
4H..|
CSP is online now
post #6 of 11 Old 03-23-2010, 10:47 AM Thread Starter
patduke90
2H 4L
.|...N
4H..|
That sounds like it might be right. When it's in 2H, it has a feeling like it is "out of gear" I can wiggle it around like it's not in anything. I just wish I could find a Shift knob for this thing that actually had the right pattern.
post #7 of 11 Old 03-23-2010, 01:52 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Those things get sloppy and are annoying to fix. Scout D20's have Dana 300-style shift brackets if you want an alternative.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #8 of 11 Old 03-23-2010, 03:20 PM
CSP
You can also use Dana 18 twin sticks on the Scout Dana 20.
CSP is online now
post #9 of 11 Old 07-04-2010, 09:07 AM
CJ7JeepChick
1979 CJ7
omg
4HI
2HI
N
(2LO)
4LO
Holy crap. That explains a lot.
CJ7JeepChick is offline
post #10 of 11 Old 07-04-2010, 09:36 AM
243
1978 FSJ Cherokee
There are some knowledgeable people here, I had no clue there were so many shift patterns for the D20.
Dave's 78 Build
243 is offline
post #11 of 11 Old 07-04-2010, 10:44 AM
JeepHammer
Running On Empty...
1973 CJ5
Not much 'Unique', just a FSJ/truck linkage.
Not so easy to change in the vehicle, but worth your time.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
cj8 , commando , dana-20 , scrambler
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 07:30 PM
Unique Cj Concept Ideas!!!!!! Smitm16 Jeep CJ Forum 14 11-03-2009 11:11 AM
1976 Quadra-Trac unique? Jim_76CJ7 Jeep CJ Forum 2 08-21-2008 12:46 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 07:56 AM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-19-2004 12:19 AM
