Undercoating - JeepForum.com
post #1 of 7 Old 01-02-2010, 09:22 PM Thread Starter
NelsonATC
1980 CJ7
Undercoating
Getting ready to do some repairs to my tub, which is currently off the frame. Plan on cutting out and replacing anything corroded, but for the most part the tub just has surface rust underneath.
What is the current consensus on undercoating? (type and how much needed if recomended)
I will be spraying it with 2 coats of Eastwood's Rust Encapsulator (which I have already). The Jeep is never garaged and I live in RI. It is not a DD and doesn't see the roads a lot in the winter, unless I am headed out to wheel it.
Mike
1980 CJ7
NelsonATC is offline
post #2 of 7 Old 01-03-2010, 06:30 PM Thread Starter
NelsonATC
1980 CJ7
Bump
Mike
1980 CJ7
post #3 of 7 Old 01-03-2010, 06:50 PM
mcmud
1983 CJ8
Well Nelson if it weren't so cold and dark out side I could give you a brand name that was highly recommended to me years ago and I have a stock of it in the barn and if I weren't so old I could remember the brand. So there you have it.
At least tonight I will commend you for sealing it up prior to applying the undercoat. And I can say that the amount to be used is relevant to just how thick you want to apply it. IIRC it will take six or seven of the larger sized aerosol cans to apply what I consider ample to be effective if you were to do the entire underside.
I will make the trip up to get you the brand name tomorrow morning and offer it for your consideration then.
mcmud is offline
post #4 of 7 Old 01-03-2010, 07:45 PM
_Kyle_
_Kyle_'s Avatar
Por-15 is pretty highly recommended.
But i'm cheap and just touch it up with black rustoleom as needed.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #5 of 7 Old 01-03-2010, 07:52 PM Thread Starter
NelsonATC
1980 CJ7
I already have and am planning on sealing first with Eastwoods, which is similar to Por-15. Looking for an undercoat to spray over it as a topcoat to hold down road noise and protect it from the elements
Mike
1980 CJ7
post #6 of 7 Old 01-03-2010, 08:44 PM
mcmud
1983 CJ8
...felt I could use a walk and you could use the tip.
I use and would recommend "Tite Seal" Rubberized Undercoating it is a SolderSeal/Gunk product. Two coats.
After applying the first coat you will have a clear understanding as how both the amount of overlap and the distance it is held from the surface will affect the texture. This is a good product. It states that it "seals against rust & corrosion muffles noise" The first part I'm just a little skeptical of, the last I'll confirm.
mcmud is offline
post #7 of 7 Old 01-04-2010, 05:44 AM
skidplate77
1977 CJ7
I used U-POL Raptor to undercoat my fiberglass tub. It's a great product, and very easy to apply. It comes with it's own spray gun in a kit. 1 kit is a 100 bucks, and it covers a 8 ft pickup truck bed. Very durable, too...
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock..
A new work in progress, and a new lease on life...
skidplate77 is offline
Cheap undercoating gun pwhit Jeep CJ Forum 14 04-21-2011 03:44 PM
Need advice on YJ tub undercoating martyweir Jeep CJ Forum 0 11-13-2009 12:15 PM
Rubberized Undercoating anyone? blacklabel000 Jeep CJ Forum 4 09-30-2008 11:27 AM
Tub undercoating JackN77CJ7 Jeep CJ Forum 9 03-19-2007 06:44 PM
Undercoating gun... pf1130 Jeep CJ Forum 23 10-22-2004 03:56 AM
