Uh oh! Coolant from the header.. - JeepForum.com
post #1 of 54 Old 01-20-2011, 03:44 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
I'm finishing up the install of my rebuilt AMC360 and was putting coolant in it for the first time today. I have open headers installed and I noticed a constant drip out of passenger side header, it's coolant. I can see that it's coming down the inside of the passenger/front tube. I pulled the header off and stuck my finger in that exhaust port and felt a good bit of coolant in there. What am I looking at here? Head gasket, intake gasket?? Man, I was hoping to have this thing running by next month...
1982 CJ-7
AMC360
4.5" RE 35" X's
Blue Jeep Club Member #1
Baloo is offline
post #2 of 54 Old 01-20-2011, 04:03 PM
turbogus
1978 CJ5
Ohhh man! I sure hope it's not a cracked head!
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #3 of 54 Old 01-20-2011, 04:19 PM
Scooter402
I'd say that's a head gasket issue...I had the same thing when the machine shop f-ed up drilling the steam holes in my heads for my SBC 402. I don't know if AMC engines have them, but you're looking at pulling the head back off.
Scooter402 is offline
post #4 of 54 Old 01-20-2011, 04:37 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
Dammit, now the other head is leaking! This one is leaking at the gasket, the exhaust ports are dry... CRAP!!! Just got off the phone with the guy that put together the short block for me. He wants me to re-torque the side that's leaking at the head gasket. For the other one leaking out of the exhaust port he wants me to remove the intake and head and bring him the head to check it. The tri-county area is going to have a beer shortage tonight cause I'ma gonna tie one on!
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #5 of 54 Old 01-20-2011, 05:41 PM
MoC
Man that stinks!
MoC is offline
post #6 of 54 Old 01-20-2011, 05:58 PM
cmvash
1973 CJ5
Since you have coolant on both sides it sounds like a botched gasket install. Surely if the head(s) were cracked they'd spot that during the rebuild.
But hey at least it leads to beer(s).
Z0NAJEEP Has Added You As A Friend!
^ Be jealous.
Originally Posted by -Zona- View Post
You know, vash, you don't poke your head around here to often- but when you do- you bring something win-worthy to the table.
cmvash is offline
post #7 of 54 Old 01-21-2011, 08:16 AM
turbogus
1978 CJ5
Mechanical skills were taught to me long ago by an old original hippie, when things went wrong he always said; "Sit back and drink a beer and think about it".
turbogus is offline
post #8 of 54 Old 01-22-2011, 08:10 AM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
I re-torqued down the driver's side head that was dripping a little at the gasket and hooked up the pressure tester to the radiator and that one appears to be stopped. I went 5 lbs over the book torque requirement.
The passenger side head, however, during the pressure test spewed more coolant out of the front exhaust port. The same place it was coming from before as I expected. It was a steady stream. So, I disconnected everything from the intake and passenger head and pulled them out... man I hate tearing apart my engine again! Everything I have done is done very thoroughly, but it seems the work the guy did on the short block is sloppy to say the least! I took some pictures after pulling the head off to take to him. There was a lot of coolant sitting on top of all four pistons... I'll post some pics when I get home. Man I'm pissed at this whole thing... next time I'll do it myself.
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #9 of 54 Old 01-22-2011, 08:21 AM
turbogus
1978 CJ5
Where have all the professionals gone? More and more over the years I'm having to do more of the wrenching (that I don't have time for) myself. I'm sorry for all of your trouble Baloo.
turbogus is offline
post #10 of 54 Old 01-22-2011, 03:22 PM Thread Starter
Baloo
Go Tigers!
Baloo's Avatar
1982 CJ7
Here's the damage on one side..
1982 CJ-7
AMC360
4.5" RE 35" X's
Baloo is offline
post #11 of 54 Old 01-22-2011, 03:35 PM
Bakunin
Bakunin's Avatar
Wow!
Bakunin is offline
post #12 of 54 Old 01-22-2011, 05:55 PM
swatson454
1983 CJ7
Look on the bright side, at least the rings seem to be holding a seal That's pretty wild, though. Did he even use the right head gasket?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #13 of 54 Old 01-22-2011, 06:14 PM
Alby63
1982 CJ5
With the motor apart that far and being antifreeze contaminated the seal on the driver's side, I would play it safe and remove and replace that gasket as well. No sense in chancing it. The builder may not have wiped off the surfaces before installing the heads.
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline
post #14 of 54 Old 01-22-2011, 07:44 PM
littlebuddie
1980 CJ7
Are you able to check the head surfaces for warp?
1980 CJ-7 258 Dana 300, SR-4 Trans, Basically Stock Except One Piece Rear Axles, Weber Carburetor.
O\lllll/O
[]=O=[]
littlebuddie is offline
post #15 of 54 Old 01-23-2011, 12:03 AM
cmvash
1973 CJ5
Good god, are you sure there's even a gasket on that side?
^ Be jealous.
cmvash is offline
258 header for CJ 7 Coyotero Jeep CJ Forum 20 07-25-2011 06:33 PM
Started without coolant, now coolant in oil. Blown head gasket? bkkrehbiel Jeep CJ Forum 6 12-26-2009 07:22 AM
Still over heating: no coolant flow, boiling coolant CJATE Jeep CJ Forum 45 07-15-2009 04:24 PM
header liftedred84cj7 Jeep CJ Forum 0 06-24-2003 12:22 AM
Header for 258 ImNotRyan Jeep CJ Forum 3 03-22-2003 10:58 PM
