type of oil - JeepForum.com
post #1 of 9 Old 07-24-2006, 08:33 AM Thread Starter
redcj576
1979 CJ7
type of oil
hi,
what type of engine oil should i use for my (1979 )305. chevy powered cj7?
thanks
CJ5 Project finally finished...
'77 CJ7 -.GM 305,T176,4.10s,37x14.5 Creepy Crawlers
'79 CJ7- 350,TH400,NP205,4.88s,39.5" Creepy Crawlers
'61 Chevy Apache 10-all stock
'90 Chevy K1500 4x4 Truck-LT265/75R16 BFG All terrains
redcj576 is offline
post #2 of 9 Old 07-24-2006, 09:26 AM
jlynch
That's a personal preference. I use valvoline 10w 30
92 Jeep wrangler/ Chevy 350/ sm465/ 205/ Dana 60/ Dana 70/ 4.56 gears/ detroit locker/
jlynch is offline
post #3 of 9 Old 07-24-2006, 09:58 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Probably your favorite 10w30 or 10w40.... I just use whatever's cheapest since it gets pumped out of the engine almost as fast as I pour it in.
BESRK is offline
post #4 of 9 Old 07-24-2006, 02:11 PM
86cj74.2L
86cj74.2L's Avatar
I use 15w40 diesel oil in the summer and a blend of 15w40 and a synthetic 5w40 diesel oil in the winter.
86cj74.2L is offline
post #5 of 9 Old 07-24-2006, 02:17 PM
KrazyGimp
1982 CJ5
You mix regular and synthetic oil? Or did I just read it wrong?
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #6 of 9 Old 07-24-2006, 02:41 PM
86cj74.2L
86cj74.2L's Avatar
Yes, I mix it in the winter 50/50.
I end up with a 10w40 semi-synthetic with all the benefits of the diesel oil additive package. They are compatible when mixed together.
I use shells Rotella 15w40 and synthetic 5w40 for my winter mix and the fleet oil our work uses and I get at 4.50 a gallon in the warmer months. (I change seasonally) I also use the larger oil filter.
post #7 of 9 Old 07-24-2006, 02:47 PM
KrazyGimp
1982 CJ5
So you can mix synthetic with diesel oil and it will work? I was always under the impression that once you put synthetic in a motor you could only run synthetic from then on. Something about additives in the synthetic oil actually repelling normal oil and causing wear on parts. Is this just misinformation or is there any truth to it?
post #8 of 9 Old 07-24-2006, 03:07 PM
86cj74.2L
86cj74.2L's Avatar
On the bottle it will say compatible with synthetic and conventional motor oils. It may just say all motor oils.
When our fleet oil guy came in and I told him I was using Shells 5w40 synthetic he got pissed because he hates Shells mas marketing approach on a what he calls a genetic not so great oil product.
Anyway he told me to mix 1 gallon of his oil to 2 gallons of the Rotella so I get the benefits of his additive package and the lower pour point of the synthetic. ( he wishes they had a synthetic oil product but most fleets always have their trucks plugged in and my area doesn't fall under the 5w30 or 5w40 synthetic oil in winter time I.E. temps in the single digits. We may get 2 to 5 of those nights during the whole winter.
post #9 of 9 Old 07-24-2006, 03:13 PM
BLS33
Chief of the brain police
BLS33's Avatar
I second that
BLS33 is offline
Transmission type? Mc83J10 Jeep CJ Forum 23 10-27-2008 07:57 AM
which type of welder? ohio77cj7 Jeep CJ Forum 9 08-01-2008 08:35 PM
holley type and dial type fuel press regulators ktm25089 Jeep CJ Forum 4 07-18-2008 04:47 PM
OIl type in my CJ7 mmerlina Jeep CJ Forum 10 11-07-2007 06:54 PM
What type of CJ is this crosbike3688 Jeep CJ Forum 21 11-06-2006 09:22 PM
