#16 | ||
http://www.4x4wire.com/tech/dana300/#FWDHi
Beer is the answer - it doesn't matter what the question is! '86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift. '04 TJ Sahara. '00 TJ Sahara. |
#17 |
Heres a link to do a twin stick conversion for cheap money
http://7slotgrille.com/tech/twin/index.html i am going to try it on mine in a few weeks.
91 XJ Limited (stock for now) |
#18 |
Good article in 4x4wire. Thanks for the link! A little scary to think about grinding on the shift rail, but I do have a spare D300 just in case.
#19 | |
Rear wheel drive - high range Rear wheel drive - low range -- only with a twin stick Four wheel drive - high range Four wheel drive - low range Front wheel drive - low range -- only with a twin stick Neutral You cannot normally get front wheel drive high range. There is a detent inside the D300 transfer case that prevents the front axle being in one ratio and the rear axle being in a different ratio. That same detent prevents the transfer case from going into front wheel drive high range. You CAN get front wheel drive high range by going inside the transfer case and removing the detent. However, you will no longer have the safeguard against different ratios selected for different axles. About the only time you'd need front wheel drive high range is if you damaged your rear driveshaft and wanted to drive home on the front axle. In that case, you'd be better off just removing the rear driveshaft and putting the transfer case in four wheel drive high range. If you have a full floating rear axle with lockout hubs, you can get front wheel drive high range by putting the transfer case in four wheel drive high range, locking the front hubs, and unlocking the rear hubs. But your rear driveshaft would still turn in that instance.
1977 CJ7, AMC360 V8 w/ headers, DUI HEI, Edelbrock intake, Holley 4150 carb, , TF999, D300, D30 front and AMC20 rear with 4.56 gears and lockers both ends, 4" susp lift, 2.5" body lift, 35" BFGs, ARG steering, 8000-lb winch, etc. |
#20 |
If you do the shift rail mod in the link above, you will be able to get front-wheel-hi and still have that safeguard.
#21 |
Took my spare D300 shift rails out last night. I'm going to try grinding the flat spot in that one first and seeing if it works before modifying my short output shaft version. I allready have the transfer case out having just replaced all the seals. I probably don't need Front Wheel drive high, but I want bragging rights...
I would not removed the "pills". No way would I trust a buddy or anyone else to not shift front and rear axles into different range. I would just not be comfortable with that. |
#22 |
WOW! You let someone else drive your Jeep! (Not even my Wife!)
#23 |
Just a little with a close eye. My buddy did over steer it and almost slam into some parked cars one time now that I think of it. I would probably be the most likely candidate in screwing it up anyhow. NO WAY is my wife trying to drive it though!!
#24 |
GROUND POUNDER
The need to be able to use Front Wheel High would be rare. If you had a rear driveline failure, you'd still have to remove the rear driveshaft or it would be spinning via the rear axle. In that case, you could just use 4 Wheel High. On the trail, I use Front Wheel Low quite a bit. I would just install the twin stick and call it good.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#25 |
I followed the procedure listed in link posted by CJ Chat. It works great.
#26 |
the only read advantage to twin sticks is the ablility to burn the front. this for most recreational wheelers would likely not be needed. W/ a standard D300 one may still get 2lo in the rear- just engage low range and leave front hubs unlocked. A alos run a klune-v under drive for more gearing options.
That's it, no other real advantage. Once on a steep trail ride i was in low range and both ARBs engaged-- about 3/4 to the top of the long climb noticed the front tires were not spinning lke the rear-- oops, i was in 2lo and locked, so you can go a long way like that and not even need the front. Still, its better to have all 4 pulling than not and yes, front burning is helpful is rare occasions, i just doubt the $$ and time needed to gain an extra lever and for rare use. JMO mb |
#27 | |
Running On Empty...
Not hard, easy to do, and only necessary if you are going to do 'Digs' either front or rear... Add an extra stick, I used the factory one, and whip up some shift rod end sockets, I stole these pictures, but they are better than I take anyway.... Longer bolt to hold the extra stick, ![]() Another shot of that, ![]() The only real fabrication, ![]() Pictures are worth 10,000 words in this case...
REMEMBER, 'Free' internet information is worth EXACTLY what you paid for it! LINK:Dual Battery Diagrams & Explanations. LINK:Winch, Welding, 'Lend Power' Project, LINK:Water Proofing Ignition, Hubs, Ect., LINK:BSERK's Winch Plate, LINK:AMC V-8 Front Cover Recondition, LINK:How An Ignition Works, LINK:Ignition Swaps '77 Older Jeeps, LINK:'78-'90 Jeep Ignition Upgrades, |
#28 |
I use my twin sticks often. I like having the all the options. I also have the Tera-low kit which I HIGHLY recommend.
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's 2010 Rubicon Unlimited 1997 TJ with various enhancements |
#29 |
That picture is one of mine and a set I made. It's a bit different than the ones on 7slotgrill. I added those tubes to stabilize the plate on the shift rod, there's zero slop in the plate, when done this way. The tubes are just bushings out of the hardware bins at Lowes.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc... 2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s............... John N |
#30 | |
Running On Empty...
OK, Picture credit to 'John N'! Like I said in my first post, I swiped the pictures, and couldn't remember who posted them originally, but the concept works GREAT! Even the shaft stop on the pivot bolt works well! I picked these pictures up 4 or 5 years ago, (From John N, thank you again!) and they really opened my eyes on how easily this could be done! We were buying the shifters with remote cables before this! This is Just TOO easy! I didn't want to post them on any web site until I found out who took them... But a BBS forum is a little different! Do you mind my using them? If so, I'll remove them from here...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
