Quantcast twin stick d-300 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > twin stick d-300
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 07-26-2007, 02:32 PM   #1
muddmonky
twin stick d-300
i have herd about people puting a "twin stick" in there t-case. what purpose does it serv if any.
and if its worth it can u put one in an automatick 1980 cj7 with a d-300 t-case.
muddmonky is offline   Reply With Quote
Old 07-26-2007, 02:39 PM   #2
marmaduke
I think the twin stick gives an option of 2wd in low ratio which you don't normally have but i think that's about it
'86 cj7, 360 cui, msd ignition, hedman htc's and still upgrading
marmaduke is offline   Reply With Quote
Old 07-26-2007, 02:39 PM   #3
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
After owning one on an Atlas ll I can tell you that it is worth it. But it all comes down to how much time on the trail you are going to put in. There will be times where you can put your rear axle in N and your front in High and allow the rear to slide the side of a rock and the front to dig etc. Most likely you will not use it every time out unless it is a built rig that is trail only. Just recently my rear cv joint went out. I pulled the rear drive shaft put the front into Hi and drove home. For most I would say it is overkill but it will help when you go to sell it. Plus.....the more levers the better
TrailWorthyFab is offline   Reply With Quote
Old 07-26-2007, 02:40 PM   #4
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
it lets you have more choices, like FWD low and RWD Low, but it also makes shifting the transfercase much easier IMHO.
'82 Scrambler - NV4500/4.5" lift/33" BFG/Holley 390 - twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - work vehicle
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
"I got a fever . . . and the only prescription is more cowbell"
CJeep is offline   Reply With Quote
Old 07-26-2007, 02:50 PM   #5
TrailWorthyFab
TrailWorthyFab.com
Maybe on the dana 300 the shifting is easier. But the only fault I have with the Atlas is the way the gears are cut it takes a little time before you learn the tricks of geting it into gear easy.
Old 07-26-2007, 02:54 PM   #6
82cjman
1982 CJ7
on the d 300 with the twin stick can you put the rear in neautral an front in high
82cjman is offline   Reply With Quote
Old 07-26-2007, 02:56 PM   #7
muddmonky
thanks
i would give up a lung for an atlas ll but i cant aford it thats y im trying to fix up the d -300 because sence we got our bronco for towing the jeep is now 100% off road and 100% low buget. (i got no money)
Old 07-26-2007, 03:33 PM   #8
Rob55
I have a Currie twin stick on a D300 (also have the teraa lo kit for the case). The twin stick lets you isolate or combine the ranges for front and rear diff. You have a greater range of options, including rear or front wheel drive only, front lo, front high, etc. The tranny being auto or stick does not affect the installation or use of the twin stick.
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back....
Rob55 is offline   Reply With Quote
Old 07-26-2007, 03:41 PM   #9
82cjman
1982 CJ7
i have a twin stick on my dana 300 how do you get it into fwd only?
Old 07-26-2007, 04:23 PM   #10
Rob55
This is the diagram from Currie - hope it helps.
Old 07-26-2007, 04:47 PM   #11
bdmonist
WTF is that?
bdmonist's Avatar
One stick controls the front and the other controls the rear - Hi - N - Low for both. You have to remove the pills(interlocks) in the TC in order to get Front High only. This will however allow you to accidently put the front in high and the rear in low which will explode your case.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 07-26-2007, 07:14 PM   #12
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I use my twin stick quite a bit to do "front digs" or "front burns" as we call them. Helps to pivot the rig around on the trail. Alot of times, I'll just leave the buggy in front wheel drive as it makes it easier to snake thru tight switchback trails..
Here's a little bit of "front dig" work.. I don't have a cutting brake so I normally power brake and then drive the front tires thru the brakes letting the rear tires drag...
http://www.youtube.com/watch?v=KszyykROt_8
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 07-28-2007, 08:26 AM   #13
4bob4
Thanks for the video I've always heard of the front dig and understood how it worked but never saw it. And may I say sir NICE SAVE!!!!!
'84 CJ7---[URL=http://www.cardomain.com/member_pages/view_page.pl?page_id=264723&make_type_query=make%3DJeep&model_brand_query=model%3DCJ7&tree=Jeep%20CJ7]My CarDomain[/URL]---[URL=http://bbb.quadratec.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=46;t=000581]My Build Up Post[/URL]
My [URL=http://www.rigrater.com]RigRater[/URL] Score: 585RRv1.0 with a BOA of 17.05 My [URL=http://dirtroad.com/jeeprate.htm]JeepRater[/URL] Score: 307
4" Superlift suspension lift/1" BL/33x12.5 MT/R's/Holley Truck Avenger Carb/Bullet Proof front and rear/a set of kc's/dual batt. tray workin on the dual battery/Chevy 350
4bob4 is offline   Reply With Quote
Old 07-28-2007, 05:37 PM   #14
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hehe.. yeah.. that one kind of snuck up on me.. should've seen my eyes as the buggy started to lean.. I looked like this------->
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 04-12-2008, 03:21 PM   #15
hansw3
1978 CJ5
interlock removal
Anyone know of a good article on removing interlock from D300?
hansw3 is offline   Reply With Quote
Glock Forum
