Twin Stick Advantage? - Page 2 - JeepForum.com
post #16 of 22 Old 09-12-2011, 09:22 PM
BagusJeep
1981 CJ7
Sorry, I meant on a standard D300 without twin sticks you will NOT get 2Lo. The only option is 4Lo.
Obviously with twin sticks you have greater choice.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #17 of 22 Old 08-10-2016, 09:17 PM
1946willys
So I see all the old twin sticks in macs and they use them going down the street I think for a night and low in each gear my question is can you the Dana 300 or in my case Dana 20 twin stick as a high and low in each gear going down the street? I know the thread was 5 years ago. But somone please answer thank you
1946willys is offline
post #18 of 22 Old 08-11-2016, 07:10 PM
John Strenk
John Strenk's Avatar
1976 CJ5
It's a theft device if used properly...
John Strenk is offline
post #19 of 22 Old 08-11-2016, 08:09 PM
BagusJeep
1981 CJ7
You can use it for a high and low in each gear but really you would not in real world driving.
A Dana 300 is 2.62:1 so top gear in Lo would come between 1st and 2nd in HI. Therefore you would go something like on a 4 speed T176 with 3.52/2.27/1.46/1.00/3.52R:
Lo 1 9.29
Lo 2 5.95
Lo 3 3.83
Hi 1 3.52
Lo 4 2.62
Hi 2 2.27
Hi 3 1.46
Hi 4 1.00
Switching in and out of Lo at the same time as shifting gears would be a pain. Easier to go through the box in Lo, change to Hi and then start in 1st gear once you are out of the rough stuff. The D300 often baulks and you stop to wrestle it in and out anyway.
The Dana 20 is 2.46:1 so much the same.
post #20 of 22 Old 08-12-2016, 11:18 AM
John Strenk
1976 CJ5
I'm going to have to save that and put it on my dash.
Maybe get an pneumatic solenoid on on the t-case and use a real Eaton shift knob.
post #21 of 22 Old 08-13-2016, 12:04 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Originally Posted by 1946willys View Post
...can you, in my case Dana 20, use twin stick as a high and low in each gear going down the street? I know the thread was 5 years ago. But someone please answer thank you
Do you mean use the transfer case to 'split' each of the gears in the transmission? If that's the question, then sure. My twin sticked Dana 20 has a 2wd hi/lo setting. But a real pain for regular driving, and imho, not a very good idea for that. I'd have to see what the resulting gear ratios would be. I'm thinking there would be a bunch of unfriendly gaps. But not certain. (BagusJeep - answered that for me...)
Most heavy duty trucks with twin sticks have them because they have two transmissions, mated inline. Most common: 4x4 (4 speed main/4 speed auxiliary - 16 gears) and 5x4 (5 speed main/4 speed auxiliary -20 gears).
Other medium duty trucks have 2 speed rear ends that are generally air shifted. Most common being the 4x2 (4 speed transmission/2 speed rear end), or 5x2 (5 speed transmission/2 speed rear end). Very common to 'split gears' with the 2 speed rear end.
"In the end...It's all Hack."
HackFabrication is online now
post #22 of 22 Old 08-13-2016, 12:47 PM
Stumpfarming
1974 CJ5
Just to clarify, the Dana 20 is 2.46:1 if it has the Bronco slider gear conversion, otherwise it is 2.01:1. Regardless, the point is well made.
http://www.jeepforum.com/forum/f22/stumpfarmings-73-cj5-build-1935041/
Stumpfarming is offline
best twin stick kit buktrk Jeep CJ Forum 7 01-07-2010 10:27 AM
Why a Twin Stick??? poppatello Jeep CJ Forum 8 11-20-2009 10:25 AM
twin stick d-300 muddmonky Jeep CJ Forum 37 12-23-2008 01:38 PM
300 twin stick ? aero mech Jeep CJ Forum 7 09-13-2007 08:30 AM
twin stick? thenubsterman Jeep CJ Forum 15 10-05-2006 10:01 PM
