#1 | |
Awww, APPLESAUCE!
Twin Stick??
Ok, I finally have discovered what kind of driveline I have on my CJ7. Any suggestions on why I don't have the "twin stick" setup on my Dana 300 transfer case? It's hooked up to a Torque Flite 727 automatic. Am I supposed to have the twin stick? I know I have a newer driveline than what came out in '77. I'd like to make this right, the gear selection on the transfercase, I hardly have to move the lever at all. Very little lever travel between 4L, N, 2H, 4H. I'll post more pics if need be, The single lever I have is hooked up to a linkage plate, and that pulls out the two pins that go into the case. One pin travels out further than the other, so the plate has to pivot between the two, as well as pull and push the pins. Any info would be great... Thanks.
![]() ![]() I am thinking that the lever I have was rigged up? Is it the right linkage? Thanks for any help...
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock.. A new work in progress, and a new lease on life... Last edited by skidplate77; 04-06-2008 at 11:59 AM.. |
#2 |
Go Wolfpack
Twin Sticks aren't factory, they're an aftermarket modification.
edit: You have the factory setup. |
#3 | |
Awww, APPLESAUCE!
4L being closest to the firewall? Forgive me for being ignorant on Jeeps, I have only owned 4WD GM trucks... I have done some research, and I have found conflicting info. I know Dana 20's are different pattern than GM, are the Dana 300's similiar to a GM? The guy I bought this from ran around with the lever pulled all the way back, I told him, I think he was running around in 4WD all the time, if the transfer case is like a GM product... Thanks again for any response... ![]()
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock.. A new work in progress, and a new lease on life... Last edited by skidplate77; 04-06-2008 at 12:18 PM.. |
#4 |
Yes, that is correct for the Dana 300.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress) 1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress) |
#5 |
Awww, APPLESAUCE!
4L, N, 2H, 4H... Similiar to the GM case... Got it! Thank You!!
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock.. A new work in progress, and a new lease on life... Last edited by skidplate77; 04-06-2008 at 12:31 PM.. |
#6 |
You can build a twin stick fairly easy using two OEM shifters. I'm getting ready to do it:
http://7slotgrille.com/tech/twin/index.html
Beer is the answer - it doesn't matter what the question is! '86 CJ7, 265 CI, DUI, TF999, Borla, Weber, 4" BDS Lift. '04 TJ Sahara. '00 TJ Sahara. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
