twin stick? - JeepForum.com
post #1 of 16 Old 10-04-2006, 03:05 PM Thread Starter
thenubsterman
twin stick?
what is the purpose of twin stick and why would you use it
thenubsterman is offline
post #2 of 16 Old 10-04-2006, 03:06 PM Thread Starter
thenubsterman
well on your transferr case
post #3 of 16 Old 10-04-2006, 03:41 PM
74_jeep
74_jeep's Avatar
1974 CJ5
If you have a locker in the front end , (ez locker ,aussie , lock right etc.. ) when front hubs and four wheel drive is engaged , these make it hard to turn on sharp narrow trails etc..
With a twin stick , you can disengage the front axle and make a turn a lot easier , then move on . Also can run in low in rear axle , while front is not engaged.
74_jeep is offline
post #4 of 16 Old 10-04-2006, 03:46 PM Thread Starter
thenubsterman
well yes i realized the 2 low basic thing going on but i never thought about the trail deffiantly should look into that my front is locked up thanks alot
post #5 of 16 Old 10-04-2006, 05:55 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
When I'm winding my way down a tight trail I frequently disengage the rear and use the front tires to pull the frontend around. Kind of have to blip the throttle a little... it's actually quite fun.
BESRK is offline
post #6 of 16 Old 10-04-2006, 06:37 PM Thread Starter
thenubsterman
oh you can just run front wheel drive thats totally bad *** can any tranmisison you twin stick have this capablity sorry trying to decide if i want to do it, i want to do it cause it just looks sweet.
post #7 of 16 Old 10-04-2006, 07:05 PM
bdmonist
WTF is that?
bdmonist's Avatar
You are actually twin sticking the Transfer Case, not hte tranny
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #8 of 16 Old 10-04-2006, 08:35 PM Thread Starter
thenubsterman
sorry i'm multi-tasking i know thats what you twin stick i'm sorry,
post #9 of 16 Old 10-05-2006, 03:17 PM
Cherokeester
Cherokeester's Avatar
1980 CJ7
On my dana 300 with twin sticks I have
2H
4H
4L
2L rear wheel
How do you get just front wheel out of it?
1980 CJ-7 with a AMC 401, RE 4.5" Lift, 4-1 Dana 300, Holley TBI Projection, 35" Goodyear MTR's
2010 Rubicon Unlimited
1997 TJ with various enhancements
Cherokeester is offline
post #10 of 16 Old 10-05-2006, 04:03 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
My D300 has 2WH, 4WH, 4WL and Front or Rear Wheel Low. I could also mess with the little "pills" that are between the shift rails to get Front Wheel High but I don't really need it. I think if you do that, you run the risk of putting one axle in high range and one axle in low range too.. could be wrong but I thought I read that somewhere.
BESRK is offline
post #11 of 16 Old 10-05-2006, 04:14 PM
bdmonist
WTF is that?
bdmonist's Avatar
Correct - If you remove the interlocks the axles can be in different ranges, which would not be good if you actually moved the vehicle
bdmonist is offline
post #12 of 16 Old 10-05-2006, 05:37 PM Thread Starter
thenubsterman
you can do this on a dana 20 also right?
post #13 of 16 Old 10-05-2006, 05:38 PM Thread Starter
thenubsterman
the 2 low and just front wheel drive
post #14 of 16 Old 10-05-2006, 05:54 PM
KrazyGimp
1982 CJ5
From what I have read here, Yes. I believe you can do it to any transfer case. Some might need to be a custom job, but anything can be done.
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #15 of 16 Old 10-05-2006, 06:11 PM
waywardfool
1973 CJ5
There are kits for the Dana 20. One stick is front axle, the other is rear. Each stick has L-N-H range selections. The D20 you can do Front 2wd H, but not 2L if you keep the interlocks.
1973 Jeep CJ-5 258, HEI, propane, T18A, Twinstick D20, 33x12.50x15's
1967 Kaiser Jeep M715 350, propane, Michelin XZL's 11x16
waywardfool is offline
How to Use a Twin Stick... poppatello Jeep CJ Forum 32 11-30-2010 06:18 PM
best twin stick kit buktrk Jeep CJ Forum 7 01-07-2010 10:27 AM
Why a Twin Stick??? poppatello Jeep CJ Forum 8 11-20-2009 10:25 AM
twin stick d-300 muddmonky Jeep CJ Forum 37 12-23-2008 01:38 PM
Twin Stick jksull Jeep CJ Forum 10 04-12-2008 10:42 PM
