Turtle71's 83 CJ7 project - Page 9 - JeepForum.com
post #121 of 186 Old 07-19-2012, 08:39 PM Thread Starter
Turtle71
1983 CJ7
You might ask why we didnt go ahead with the OME leafs? After all, we had the old ones partially disconnected. Heres the predicament I am in at the moment.
Since time and money are both factors, I decided to look for some axles already geared the way I wanted. I found some axles with 4.10 gearing. We agreed on a price that the seller suggested. Then when the time came for me to get them, he made excuses for not being available and then would not respond. I found out recently that he is still trying to sell the whole lot of disassembled parts he has as a whole. Since I can't find any axles, I can't run 33's. If I can't run 33's, I don't need the 2.5" OME leafs yet. Hence have taken a bit of a detour from the original plan with the suspension.
After getting rid of the PO's hack job on the rear crossmember, giant rear shackles and lack of rear body bushings, we took it for a drive. Although the ride was slightly improved and obviously safer, it was still quite rough. We decided new shocks were in order. Found some that were budget friendly on rockauto.com.
After install we were pleasantly surprised at what a difference they made in the ride.
Here is how it sits. A little higher in the front at least. Not exactly sure of how everything ended up until I take another measurement.
My 83 CJ7 Build:
Turtle71 is offline
post #122 of 186 Old 07-19-2012, 08:46 PM
twinstickd20
1979 CJ7
Originally Posted by Turtle71
Thanks....Its just a replacement crossmember from morris4x4. But anything looks better than what was on there.
Ahh okay I see, I know how that is mine had 2 plates welded to the ends of the frame and a 1 inch thick solid square bar tied them together and had a ball welded on in the middle and looked extremely safe :haha:
My Build Thread
twinstickd20 is offline
post #123 of 186 Old 07-19-2012, 08:57 PM Thread Starter
Turtle71
1983 CJ7
The next thing we want to tackle is the steering. When driving, it seems to have a slight delay when turning the wheel one way or another. It has a 1 inch body lift and YJ rear shackles but I am not sure about the leafs. As mentioned earlier, when I got the Jeep it had Rancho shocks but I could not find any marking on the leafs. I am pretty sure they are stock.
What I am getting at is I don't know if the reason for my steering issues is the caster problem I have read about when a CJ has a suspension lift. I'm sure the tie rod end could use replacing, but I just greased them for the moment. I also made sure the steering box bracket was tight.
I am begining to wonder if these may be a factor in the steering delay? What do you guys think???
If these are like the shocks were then they are shot. Could they cause something like I described? Would I better off without them?
My 83 CJ7 Build:
Turtle71 is offline
post #124 of 186 Old 07-19-2012, 10:46 PM
Blue83CJ7
1980 CJ7
I would check the joints in your steering shaft, and also check your shackle bushings and or front shackle hangers.
When I turn my wheel, I can see the whole body shift from left to right over the axle before it starts turning the wheel, and the shackles do like below, which i think that's a combination of bushings and hangers being worn and I might order front crabtrees to fix it (after I try welding the stock ones and butcher them to try to save money, then realize I shoulda just bought crabtrees)
Turn Center Turn
1980 CJ7 - The Grenade
Blue83CJ7 is offline
post #125 of 186 Old 07-19-2012, 10:48 PM
Blue83CJ7
1980 CJ7
Also your sway bar bushings look pretty beat, but that shouldn't cause this problem... Might start clunking when you hit bumps though
post #126 of 186 Old 07-20-2012, 04:44 AM Thread Starter
Turtle71
1983 CJ7
Turn Center Turn
Thanks Blue. Is there any best way to check the steering shaft joints? I twisted it by hand and the upper joint seemed to be ok. Will have to recheck. Although the front shackles/bushings are not near as long bolt to bolt as the rears were, I had not noticed if they are moving as you described or not. Will check them also.
My 83 CJ7 Build:
Turtle71 is offline
post #127 of 186 Old 07-20-2012, 01:47 PM Thread Starter
Turtle71
1983 CJ7
Will definitely be getting around to all the front end bushings soon. I might just remove the front stabilizer shocks this weekend and see if it helps. Any opinions on this?
My 83 CJ7 Build:
Turtle71 is offline
post #128 of 186 Old 07-20-2012, 02:34 PM
twinstickd20
1979 CJ7
Couldn't hurt, your drag link is flat enough you shouldn't have any bump steer anyways.
My Build Thread
post #129 of 186 Old 07-20-2012, 05:52 PM Thread Starter
Turtle71
1983 CJ7
Thats what I was thinking. Will give it a try tomorrow.
My 83 CJ7 Build:
Turtle71 is offline
post #130 of 186 Old 07-20-2012, 06:58 PM
Skerr
Just putting new bushings up front will make a huge difference in the handling. You surely don't need dual stabilizers.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #131 of 186 Old 07-20-2012, 09:58 PM
CTIIpilot
Congrats, great deal for $800
CTIIpilot is offline
post #132 of 186 Old 07-20-2012, 11:22 PM
MoC
Just catching up, great progress! I would ditch the duel stabilizers as well, will make it easier to hunt down the problem.
The stabilizers are just a band aide that covers up the problem. I run 36's swamper tsl sx's, 4.5 " spring lift, 1 " body lift, 4 inch drop pitman arm, big daddy tie rod and drag link flipped and can 1 finger at 55 with no stabilizer. All my bushings have been replaced, shocks, my perches moved to fix caster. No bump steer, no wander. Drives better now than when I got it all stock with 31's.
MoC is offline
post #133 of 186 Old 07-21-2012, 01:13 PM Thread Starter
Turtle71
1983 CJ7
Thanks CTII!
My 83 CJ7 Build:
Turtle71 is offline
post #134 of 186 Old 07-21-2012, 01:28 PM Thread Starter
Turtle71
1983 CJ7
Thanks MoC! I hope to get mine to perform like yours. I removed the dual stabilizer setup this morning.
It looks a lot less cluttered/junky now.
I checked the front shackles for any movement while turning the wheel and they checked out good. Then I made sure all the tie rod ends were greased and took it for a spin. Steering seems to have improved although some delay is still there and the steering wheel does not return to center. This is my first jeep so I am not sure what is considered normal. Maybe some steering delay is to be expected, but should I be having the "not returning to center" issue with basically no suspension lift???
My 83 CJ7 Build:
Turtle71 is offline
post #135 of 186 Old 07-21-2012, 04:46 PM
243
1978 FSJ Cherokee
It looks real good, I will need to replace my springs down the road since they have sagged quite a bit.
Dave's 78 Build
243 is offline
'82 Project CJ7 Kdozier Jeep CJ Forum 69 10-19-2013 09:17 PM
New project DaMoose Jeep CJ Forum 2 07-03-2010 11:07 AM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
New Cj5 Project!! dbarnhart4 Jeep CJ Forum 3 04-25-2009 11:33 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
