Turning off / Turning On Problems - JeepForum.com
post #1 of 4 Old 07-19-2010, 08:51 AM Thread Starter
Dudman5703
Alright, so I just went to the sand dunes the otherday and it was a bumpy ride and had some problems.
But now at first I had a dieseling problem where it wouldn't shut off. But i was told if it runs to hot it could do that, and since the battery fell down on the heater hose and was holding it down it was running a bit hot.
But now it wont start. I turn the key and all the guages turn radio kicks on ect. I turn the key all the way and nothing. Then I try to turn the key to just acc again and nothing turns, no radio.
So I disconnected the battery, which it was sparking like something was using it. I put the terminals back on, and it tried cranking and turning on... I quickly disconnected it and then tried to put it back on. Then it just repeated where I would turn the key then nothing.
So I disconnected the solenoid, and it made no difference. So maybe its a problem w/ the starter? I wasn't sure and figured some brain storming would be best before I rip it apart.
°llllll° Money well wasted
Dudman5703 is offline
post #2 of 4 Old 07-23-2010, 12:47 PM
cmcstotts
1976 CJ5
Sounds to me like the switch at the end of the steering column. I had a similar problem loosened the two screws holding the switch everthing started working. The key pushes a long rod through the column and engauges the switch. Some how it was tweeked just enough not to allow the rod to operate correctly.
cmcstotts is offline
post #3 of 4 Old 07-23-2010, 12:48 PM
cmcstotts
1976 CJ5
It is located on top of the column under the dash. "Ignition switch"
post #4 of 4 Old 07-23-2010, 02:33 PM Thread Starter
Dudman5703
actually the solenoid was stuck;
so it just kept cranking the engine.
replaced it - go to go.
turning rotors twoleos617 Jeep CJ Forum 3 01-06-2010 07:04 AM
HELP!! 258 isn't even turning over ccbhunter14 Jeep CJ Forum 8 06-09-2009 11:04 PM
Tires not turning all the way.. mmerlina Jeep CJ Forum 6 04-27-2009 07:22 PM
turning radius meatloaf Jeep CJ Forum 9 12-07-2008 12:21 AM
Turning the distributor marmaduke Jeep CJ Forum 0 03-23-2007 02:52 AM
