Turn Signal Reminder - JeepForum.com
post #1 of 25 Old 06-09-2008, 04:57 PM Thread Starter
whizerd
1972 CJ5
Anybody know of a product that I can put on my old CJ5 to remind me that my turn signal is still blinking?
I have dummy lights, but the older I get the more help I need!
A beeper or some kind of sound.
Thanx!
Whuzerd
whizerd is offline
post #2 of 25 Old 06-09-2008, 05:45 PM
NHwheelin
1991 XJ Cherokee
im sure there is away to hook up a buzzer of some sort that will buzz when your lights blink. just not sure excatly how to go about it.
91 XJ Limited (stock for now)
NHwheelin is offline
post #3 of 25 Old 06-09-2008, 06:08 PM
John Strenk
John Strenk's Avatar
1976 CJ5
I think a $12.00 buzzer from Radio Shack would work fine. I'll have to figure out a simple connection. Looks like a couple of diodes right now.
John Strenk is offline
post #4 of 25 Old 06-09-2008, 07:17 PM
jeepskate
Yup, a little Radio Shack beeper/buzzer will work. One of my buddies has a CJ-7 that he bought from an older in-law who installed one. Should just be able to tap into the flasher socket on the fuse block (not familiar with the pre-'76 stuff, so I'm not sure what you have to work with on that front).
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #5 of 25 Old 06-10-2008, 01:50 PM
Fjguercio
1978 CJ7
Yes the radioshack buzzer would work well and give you an audio on signal. I would suggest a IDC Splice, (insualtion displacement) into the wire going to the lamp wire going to the Speedo Dash Cluster that blinks the turn arrow. The Buzzer would get the + from the lamp wire and ground the - to the dash. This could hang under the Dash. If you ever want to remove just unclamp the IDC Splice remove the ground wire for buzzer and done.
The interesting part is getting it to BUZZZ for the left and right with out intoducing a short of the + wires when attached to the Left/Right Signal Arrow Lamp. Could use TWO BUZZERS and attache one to the left and one to the right lamps. The other idea would use ONE BUZZER and with a + feed from the Left & Right lamps but use a diode inline with the + 12V feed. If a diode is not used with One Buzzer the left lamp will light up the right lamp arrow or some of the lamps.
If you can find cheap 12V Buzzers could use two of them that would be a good solution and keep simple at the same time. Attach one buzzer to each of the lamp turn wires and ground to dash.
IDC Clamp + ---------------------->diode----------------Buzzer----ground
for 18 awg range R. lamp wire
IDC Clamp + ----------------------->diode----------------
L. lamp wire
IDC Clamp + --------------------------------------Buzzer I---ground
IDC Clamp + ---------------------------------------Buzzer II---ground
L. lamp wire
The last idea is to use the flasher modual and power the Buzzer from there. This may allow the use of one Buzzer and not have to use the diodes.
Hope this helps
Fred
Fjguercio is offline
post #6 of 25 Old 06-10-2008, 02:12 PM
Mike Romain
Too complicated.. ;-)
The flasher unit has two legs, one leg will provide a pulse of power to a buzzer won't it?
Mike
Mike Romain is offline
post #7 of 25 Old 06-10-2008, 02:24 PM
Fjguercio
1978 CJ7
Sorry, do not have good way to do drawing. The --- are wires.
The orginal poster should tell the year of his CJ5 to look at electrical skematic. If one flasher modual that should work also, that was my number 3 or last alternative.
Fred
post #8 of 25 Old 06-10-2008, 02:37 PM
Mike Romain
Fred
I guess I should have read it all the way to the bottom then now shouldn't I....
Sorry, you lost me 3/4 the way through.
Mike
post #9 of 25 Old 06-10-2008, 03:16 PM
pu70
How about this. Im sure someone else makes them too.
http://www.tricoproducts.com/index.cfm?location_id=130
pu70 is offline
post #10 of 25 Old 06-10-2008, 03:19 PM
John Strenk
1976 CJ5
Let see the buzzer is connected to hot so the blinker is always hot. Hooking the buzzer up to the blinker will make it sound all the time. So that won't work unless you want to get use to the buzzer and when it stops buzzing you will know the TS are on.
I realy don't see any way around this without using two buzzers or two diodes and a buzzer. Make sure you connect it to the front Turn Signals or the buzzer(s) will sound any time you hit the brakes.
post #11 of 25 Old 06-10-2008, 03:23 PM
John Strenk
1976 CJ5
Nah, that would be to simple. What CJ owner doesn't want to hack up his harness for the next owner to have fun with.
post #12 of 25 Old 06-10-2008, 03:27 PM
Mike Romain
Got one, they don't help.
Mike
post #13 of 25 Old 06-10-2008, 03:36 PM
Mike Romain
If the buzzer tags the output leg of the flasher and has it's own ground, I don't think it will see backfeed through the open switches to the buzzer when the brakes come on. They are on separate fuses and don't use ground theft....
I might have to check that with my meter as I am also interested in a warning.
Mike
post #14 of 25 Old 06-10-2008, 03:46 PM
John Strenk
1976 CJ5
Eureaka!!
How about putting the two leads of the buzzer across the two leads of the flasher. Anytime the Flasher opens when flashing the turn signals, it will Buzz.
You could probably glue the buzzer to the flasher and run the wires down to the terminals and solder them on and Then you can just plug it in.
Sounds like a good product idea someone will market in a couple of days. I'll take 1% of sales thank you.
post #15 of 25 Old 06-10-2008, 05:11 PM
Fjguercio
1978 CJ7
The Buzzer will have two leads, one of each + -. The + leg can be spliced into the lamp wire for the arrow and the - ground leg can be attached to the metal dash via a screw and star lock washer. TWO buzzers and do one for the left and right lamp arrows. This will buzz each time the lights flash on. This will also need to be fairly loud in the 65db range or more or you will not hear it. Bring a 12transistor battery to radio shack and you can test how loud the buzzer is.
There are also connectors that will go thru the insulation and make contact with wire with out breaking the wire. These type of connectors are called IDC, insulation displacement connectors, and are nice for quick fixes, non critical stuff, and for those of us that cannot solder.
The red connectors are folded over the wire and squeesed with plyers to make eletrical contact. One of them is closed on half of the connector. I used an LED to simulate the Buzzer we are talking about.
Here is a pic of a two wire device, similar to what Buzzer would be, with the + leg in the IDC and another IDC so you can see it completly open. The black lead is most likely ground -.
I have not looked at the flasher modual on my CJ to see how many legs it has, as for ground, hot+, Hot + switched. Could be 2 or 3 leg. If 2 leg and John S. method is used it will most likely slow down the flash rate or not flash at all because there may not be enough current flow thru the flasher. Guess on my part. Some of the current will go thru flasher some will go thru the buzzer. Again guess on my part.
Fred
Turn Signal TKFireman Jeep CJ Forum 1 09-08-2009 07:34 PM
Turn Signal Switch Help (where to get one) Scuter83 Jeep CJ Forum 1 04-03-2009 12:15 PM
'74 CJ5 Turn Signal Issue Scuter83 Jeep CJ Forum 2 04-19-2007 07:27 PM
CJ Turn Signal skyjeep Jeep CJ Forum 3 04-24-2006 04:21 PM
Turn Signal CJ5911 Jeep CJ Forum 0 01-08-2006 11:07 PM
