turn signal problems on 80 cj7 - Page 2 - JeepForum.com
post #16 of 31 Old 11-15-2013, 11:49 AM
Jeeper4x
The harness has not been messed with. Everything worked fine, until my brother drove it. Lol. He said that he just drove it fishing and drove down some gravel roads.
Jeeper4x is offline
post #17 of 31 Old 11-16-2013, 11:45 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Sounds like the Turn signal swich is messing up and the Emergency flasher is coming into play when the turn signal is activated. Check the emergency flasher button.
All the dash lights or just the speedometer dash lights?
John Strenk is online now
post #18 of 31 Old 11-17-2013, 11:29 AM
Jeeper4x
No. When the headlights are on. The left signal works, the right does not. But when you turn off the headlights, the left signal works fine, when you switch to the right, the dash light flash and all 4 lights flash. I have replaced the turn signal switch and re wired the rear lights. It still does the same thing. I'm at wits end. Could it be the gauge panel?
Jeeper4x is offline
post #19 of 31 Old 11-17-2013, 02:59 PM
John Strenk
1976 CJ5
I don't blame you for getting frustrated.
What you are describing could be a grounding problem or a short.
Disconnect the right rear tail light and see if the dash light still flashes. Try it with just the bulb out.
post #20 of 31 Old 01-24-2014, 07:17 AM
Purplehaze1786
1980 CJ7
Jeeper4X....I have/had the EXACT same issue with my 1980 CJ7. It all started with what I thought was a burnt out left front turn signal...boy was I wrong. I ended up replacing ALL the light wiring between the fuse block and and headlights, and added all new bulbs just to be safe. I also added a new speedo cluster because the old one wasn't working. My first attempt failed, and ended with the dash lights blinking when I used the right turn signal. After lots of head scratching, I checked my grounds, and actually ran new grounds from my turn signal housing to my frame. I also ran a ground wire from my speedo cluster to the frame. PROBLEM SOLVED.
My CJ doesn't leak oil, it marks its territory.
Purplehaze1786 is offline
post #21 of 31 Old 02-25-2014, 10:09 PM
krex1985
1979 CJ7
Jeeper x how did you fix the issue I have the same problem right now in my 79 cj7?
krex1985 is offline
post #22 of 31 Old 02-27-2014, 04:45 PM
Jeeper4x
Turn signal problem
Fixed it: it was the ground on the right front signal housing. I cleaned it with a wire brush. I then made a ground wire from the housing to the body. (On the fender well). I have another problem. I just put a new fuel sending unit in, I still get no reading on the guage. Any help please?
Jeeper4x is offline
post #23 of 31 Old 02-28-2014, 02:38 AM
John Strenk
1976 CJ5
Make sure it's grounded properly also.
post #24 of 31 Old 02-28-2014, 03:33 PM
Jeeper4x
I rechecked the ground wire. I ran it to the frame. Still no fuel guage. Also, my volt meter is reading 16 volts and temp guage doesn't work and neither does my oil pressure guage. Every heard of that dash panel that comes from "Jegs". They sell. A digital panel that has the speedo, temp, oil pressure and fuel. It measures 11 3/4" X 4" and 3/4" thick. It cost $350. I'm really thinking of taking all of the jeep stuff out and building a flat panel, then installing the panel from Jegs. Also, anyone have a set of used 4.56 gears for an AMC 20 and a Dana 30 axles?
Jeeper4x is offline
post #25 of 31 Old 02-28-2014, 04:56 PM
John Strenk
1976 CJ5
You Might like one of these for that price
http://www.speedhut.com/customizer.i?clid=1766501
post #26 of 31 Old 03-01-2014, 07:08 AM
Mike Romain
Is the mesh ground strap from the engine head to the firewall still there? There is also one that goes across one of the motor mounts from the block to the frame for the frame ground. These tend to rot off and not get replaced.
Mike
Mike Romain is offline
post #27 of 31 Old 03-02-2014, 10:19 AM
Jeeper4x
Ground issue
I will have to check. I bought the jeep a year & half ago. It was all stock I thought. The guy came out with 2 titles, on for a 77 & one for a 79. I quickly found out that it was. A 77 body on a 79 frame. The first thing I did was order a lift kit and tires. I found that it had a fence pipe for exhaust and no muffler. It is a work in progress. I put bed liner on the body armor and painted the rest of the jeep black. When I got it it had no turn signals or brake lights. Headlights only. I'm slowly getting her back into shape. Thanks for all of the help guys.
Jeeper4x is offline
post #28 of 31 Old 03-03-2014, 05:48 AM
jeepduo
1978 CJ7
Best thing you can to do is to run a separate ground wire to everything. I had the same problem. The body grounds on Jeeps are hopeless, and you will only put the problem off. Run ALL wires back to the battery ground.
1978 CJ7, Driving, but never finished
jeepduo is offline
post #29 of 31 Old 03-04-2014, 11:35 AM
Jeeper4x
Thanks. I may try that. I'm about ready to sell it an buy a 66-77 bronco. Lol. Just kidding. I have way to much money in my cj.
Jeeper4x is offline
post #30 of 31 Old 05-13-2014, 03:49 AM
jdulmer
I have three ground straps on my '83 CJ7.
Battery to Frame
Battery to Body (firewall)
Engine to Frame
I have not a single ground issue.
jdulmer is offline
Turn signal Problems... Please Help!!! hookntail Jeep CJ Forum 10 10-03-2008 11:14 PM
Turn signal problems sboarder3303 Jeep CJ Forum 31 09-17-2008 05:54 AM
Turn signal problems.... ego99 Jeep CJ Forum 8 11-25-2007 07:03 PM
cj-5 turn signal problems russvangundy Jeep CJ Forum 1 04-02-2006 06:58 AM
turn signal problems outdoordad@comc Jeep CJ Forum 9 02-13-2006 12:36 PM
