turn signal problems on 80 cj7 - JeepForum.com
post #1 of 31 Old 01-11-2010, 08:41 PM Thread Starter
slymongoose
1980 CJ7
my turn signals have been acting strange .. at first it seemed like the right turn signal was working fine but the left one didn't work at all....the light would stay lit on the instrument cluster, but that's it. nothing would happen with it.
so i was thinking of replacing the switch in the steering column ...
but now it seems like i can get both turn signals to work, if the headlights are off. when i turn the headlights on, the turn signals stop working (neither of them work).
so now i'm a little confused....could it be the head light switch? or bad wiring?
even when they are working, the turn signal switch on the column still seems to be acting a little weird...sometimes i'll have to wiggle it to get the turn signal to come on.
any suggestions? thanks!
slymongoose is offline
post #2 of 31 Old 01-11-2010, 08:54 PM
Aduffy32
check your grounds. it usually solves the problem.
jeepaholic
Aduffy32 is offline
post #3 of 31 Old 01-12-2010, 03:59 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Sounds like you first have a ground problem like Aduffy32 says but you may be headed into a switch problem down the road.
John Strenk is offline
post #4 of 31 Old 01-12-2010, 04:14 AM
cw4stein
1981 CJ7
x3 for the grounds. I had the EXACT same issue on my 81 when I bought it. The ground was corroded and the screws that hold the lights to the grill were loose so the lights didn't have a solid connection.
cw4stein is offline
post #5 of 31 Old 01-12-2010, 06:35 AM
Mike Romain
The rear fixtures use the bolts for the ground and the front fixtures use special shoulder screws for the ground for the signals. The running lights use a wire for the ground in the back.
If your screws aren't tight or are rusty, you can have your symptoms. Lots of folks that put brush guards on the lights have this issue too because the bolt moves to a rusty spot.
Mike
Mike Romain is offline
post #6 of 31 Old 01-12-2010, 12:17 PM Thread Starter
slymongoose
1980 CJ7
thanks for the replies, i'll check the grounds and see what i can find out.
so ... what you guys are saying is that the bad ground might not necessarily be under the dash? it could be around the headlights or tail lights even?
post #7 of 31 Old 01-12-2010, 06:45 PM
cw4stein
1981 CJ7
The factory ground wire is connected to the grill. The turn signals rely on the light housings being solidly connected (grounded) to the grill. In my case, the screw holes in the grill were worn out and the screws were always loose. I ended up repairing the holes and getting 4 new screws and all is right with the world. I also disconnected the factory ground wire, cleaned and burnished the mounting area, and installed new hardware there too.
cw4stein is offline
post #8 of 31 Old 01-12-2010, 07:16 PM
jeepduo
1978 CJ7
I think everyone has agreed, bad ground. Jeeps are notorious for that.
1978 CJ7, Driving, but never finished
jeepduo is offline
post #9 of 31 Old 01-12-2010, 07:27 PM
Aduffy32
your telling me... Just finished spending hours re-wiring the back of my jeep. :/
jeepaholic
Aduffy32 is offline
post #10 of 31 Old 01-13-2010, 06:03 AM
Mike Romain
Not really, the turnsignal grounds aren't around anything, they are the actual bolts and screws that hold the fixtures on. Rusty or loose bolts or screws = no ground.
Mike
post #11 of 31 Old 01-13-2010, 08:50 AM
John Strenk
1976 CJ5
there are very few things grounded on the dash. Mainly gauges and dash lights.
Just about every other electrical component is grounded at their mounting point.
post #12 of 31 Old 11-13-2013, 06:44 PM
Jeeper4x
Turn signal issues
Speaking of turn signal issues. My 79 cj7 has a problem. The left signal works fine, but when you turn on the right signal, my dash lights flash, both the rear signals flash. Also both front flash, only on the right side. When you turn on the lights the same thing happens. Any suggestions?
Jeeper4x is offline
post #13 of 31 Old 11-13-2013, 06:46 PM
Jeeper4x
Oops
It's a 77 on a 79 frame, with 84 wide track axles
Jeeper4x is offline
post #14 of 31 Old 11-14-2013, 09:30 AM
John Strenk
1976 CJ5
Dash lights flash on and off with the headights either on or off?
Has anyone messed with the harness?
post #15 of 31 Old 11-15-2013, 11:47 AM
Jeeper4x
When the headlights are on. The dash lights don't flash, but the right signal don't work. When you turn off the headlights, the signal works, but all four flashes and so does the dash lights
Jeeper4x is offline
Turn signal Problems... Please Help!!! hookntail Jeep CJ Forum 10 10-03-2008 11:14 PM
Turn signal problems sboarder3303 Jeep CJ Forum 31 09-17-2008 05:54 AM
Turn signal problems.... ego99 Jeep CJ Forum 8 11-25-2007 07:03 PM
cj-5 turn signal problems russvangundy Jeep CJ Forum 1 04-02-2006 06:58 AM
turn signal problems outdoordad@comc Jeep CJ Forum 9 02-13-2006 12:36 PM
