Turn signal problems - JeepForum.com
post #1 of 6 Old 10-30-2013, 05:14 PM Thread Starter
kwsjeep1
1976 CJ5
Need your help please. I have turn signal problems.
With headlights and running lights off, the back turn signals work great. Front turn signals do not light up. With running lights or headlights on, the back turn signals don't work (they stay lit like running lights) and the front turn signals don't blink but are on for running lights. Other lights such as head lights, brake lights and back up lights work great. I have traced wires and all looks good. All bulbs are fine.
Any ideas? I'd really appreciate a little help.
Thanks
kwsjeep1 is offline
post #2 of 6 Old 10-30-2013, 06:28 PM
wishfulthinking
1982 CJ7
Recheck your grounds. I had a similar problem and went back through the grounds and finally found where the issue was.
wishfulthinking is offline
post #3 of 6 Old 10-31-2013, 02:29 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Particularly how the front turnsignal housing is attached to the grll. They use a special screw here that makes contact with the housing and the grill for ground without crushing the plastic lens.
John Strenk is offline
post #4 of 6 Old 10-31-2013, 09:20 AM Thread Starter
kwsjeep1
1976 CJ5
Thanks, I'll check the grounds and the screws when I return form a business trip and let you know.
kwsjeep1 is offline
post #5 of 6 Old 11-04-2013, 01:29 PM Thread Starter
kwsjeep1
1976 CJ5
ok, screws on front lights tight and well grounded.
Wiring back traced as far as possible all looks good and connected to ground wire from box on wiring harness.
Any other ideas?
kwsjeep1 is offline
post #6 of 6 Old 11-05-2013, 07:09 AM
John Strenk
1976 CJ5
Any other ideas?
Which 'box' are we talking about?
If your talking about the firewall connection, there is no dedicated ground in there...
cj5 , lights , turn signals , wiring
