Turn signal/Parking lights to running lights - JeepForum.com
post #1 of 5 Old 09-25-2011, 03:44 PM Thread Starter
HMS
I swear my gray CJ is invisible on asphalt roads. Other drivers just don't seem to see me sometimes. Therefore, I was thinking there must be a way to make the turn signal/parking lights burn both filaments as a running light and just be interrupted when signaling.I think it would look cool and serve my purpose.
Has anyone tried this?
Howard
HMS is offline
post #2 of 5 Old 09-25-2011, 05:50 PM
lucdog
lucdog's Avatar
1980 CJ5
What would you use for brake lights? There was a thread, a while back about using aluminum faced duct tape, inside the light housing. I think it made mine brighter.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 5 Old 09-25-2011, 06:29 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
I'd like to see a picture of these turn signal or running lights.. and if you find out where to get them... thanks..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #4 of 5 Old 09-25-2011, 06:34 PM Thread Starter
HMS
I read about some type of device that ran your parking light bulbs on both elements when the ignition was on then just cancelled the appropriate light in a blinking manner when the turn signal was turned on.
Howard
HMS is offline
post #5 of 5 Old 09-25-2011, 06:35 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Howard
It happens all the time with a bad ground.
But yes It could be done. Let me think of the simplest way.
They have to be ON when the parking lights are on but OFF when they are not. Also you still have to retain the isolation between the left signal and right signal so you cant simply connect them to the parking lights.
Really though, most people cant see my jeep even with the headlights turned on.
John Strenk is offline
Turn signal indicator lights on?!?! From78To83 Jeep CJ Forum 5 04-28-2011 02:42 PM
turn signals on front parking lights SToth66cj5 Jeep CJ Forum 8 02-09-2011 05:20 AM
Front running/turn signal lights... 07wurubi Jeep CJ Forum 1 11-17-2010 08:35 PM
Brake lights and right turn signal aaveryy Jeep CJ Forum 4 05-12-2009 04:32 PM
CJ lights, no headlights, rear running lights and front parking lights on constant Blthomas Jeep CJ Forum 25 02-17-2009 12:28 PM
