Turn Signal Issues (Won't Blink) - JeepForum.com
post #1 of 16 Old 11-26-2011, 07:18 PM Thread Starter
Baldum
1984 CJ8
Hey all!
Just joined the forums This place seems great
I have a 1984 CJ-8 that I've been restoring over the past year. With the body work mostly done I'm onto the electrical.
I did my research, but please bear with me as my electrical skills are less than adequate.
As the title suggests, my front turn signals will not blink. The parking lights will go on; when I flip the stalk, however, the respective light appears to get brighter (as if the second coil is lighting) but won't blink. The dash lights go on, but also don't blink. I currently don't have tail lights so I cannot use them to troubleshoot.
From my research I can figure it's a relay, an "in-line" flasher or the switch in the column. I'm not too positive however, how can I troubleshoot?. Any thoughts?
Baldum is offline
post #2 of 16 Old 11-26-2011, 07:24 PM
WoodyHD
1983 CJ7
I think your problem might be due to you not having taillights installed. I had the same problem as you. Problem was I had a bad set of led taillights that were progressively burning out individual leds. Same problem even when I unplugged both bad taillights (imitating no taillights such as yourself). Replaced and problem fixed.
WoodyHD is offline
post #3 of 16 Old 11-26-2011, 07:34 PM
lucdog
lucdog's Avatar
1980 CJ5
I would second the rear lights being hooked up. I believe the flasher itself needs resistance to work. There's not enough with just one light.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 16 Old 11-26-2011, 08:49 PM Thread Starter
Baldum
1984 CJ8
Good point, they were shining quite brightly come to think of it.
Sound's good. Thanks a lot, hopefully that solves it
Baldum is offline
post #5 of 16 Old 11-26-2011, 08:57 PM
bentring
1976 CJ5
Bill
Pretty sure you're correct about resistance needed. It could explain why olders cars often blink very rapidly or not at all of you have a blinker light burned out.
bentring is offline
post #6 of 16 Old 11-27-2011, 08:13 PM
TJ0002
Your right on needing the resistance to make them blink.
But he could also have a bad ground on the front lights. On my 79 the rears would blink but not the front. Finally figured out the side markers would blink on when the fronts would blink off. After thinking back years ago to my 76 that was new thats how they worked too. Found out the light on the front grounds with just the mounting screws and they were rusty so they were not grounding. Took a battery bost brush and cleaned up the sockets replaced the rusty bulbs and ran in some new screws and they work like new...
TJ0002 is offline
post #7 of 16 Old 11-27-2011, 08:21 PM
Micahbo
1977 CJ5
I was having the same issue this past weekend, I changed out the flasher relay in the fuse block (they are 2.50 at the local parts store) but I also had to change out the contact inside the bulb housing because it was not making good contact. This is on my 77, so you may have a different setup, but my issues were solved.
Micahbo is offline
post #8 of 16 Old 11-27-2011, 09:13 PM
mopar346
The lack of taillights is the answer or at least you cant determine anything else until the circuit is complete.
Careful your character's showing
mopar346 is offline
post #9 of 16 Old 11-29-2011, 07:49 PM Thread Starter
Baldum
1984 CJ8
Well, I added tail lights and the driver's side lights will blink. The passenger side, however, will not. Is this a case of bad grounding? If one side works but the other does not could it possibly be a bad signal switch at this point?
Baldum is offline
post #10 of 16 Old 11-29-2011, 08:33 PM
Foundrydude
Get a transistorized flasher instead of a silver can thermal flasher. Thermal flashers are resistance based, transistor flashers have a little circuit board.
One working, one not tells you there's a difference in resistance side to side. May be a bulb not working or may be mismatched bulb numbers. Like a 1056 and and a 2056 look the same but the 2056 is a higher wattage bulb. Same will 1157 and 2057.
good luck
Foundrydude is offline
post #11 of 16 Old 11-29-2011, 09:19 PM
lucdog
lucdog's Avatar
1980 CJ5
good luck
Dude, how do you tell one from the other.
On the bulbs, I was told in a Harley Davidson forum, some time ago, that the 20 series bulbs were just a heavy duty bulb able to withstand vibrations better.(mainly used by tractor/trailer rigs), These are the only ones I use. I don't feel there any brighter.
Looks like a Google search is in order.
Thanks about the flashers, Bill
On edit, after a quick search, (5 links on the first page) I feel I'm correct. In fact some said the 20 series bulbs they thought were a little dimmer. Looking at a bulb wattage/lumens chart, they look to be the same. A heavier filiment and thicker glass was also noted.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #12 of 16 Old 11-29-2011, 09:20 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
good luck
+1 Ditto.... check for mis-matched bulbs with differnent ratings. That will cause this symptom every time.
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #13 of 16 Old 11-30-2011, 05:53 AM
Foundrydude
OK, 20s may be a heavy duty but the point of my post is the last 2 bulb digits signify interchangeability. So if you have a 1056 on one side and a higher watt 1156 on the other, one side may not flash if you're on the edge of the flasher's target resistance.
Transistorized flashers are towing flashers and don't come in a silver aluminum can, they typically have a smoked tint plastic instead of the silver can.
post #14 of 16 Old 11-30-2011, 07:18 AM
JeepFish1979
1979 CJ7
Do both brake lights come on? I had to tweak both of my taillight sockets to make good connection on my bulbs. But the brake light uses the same wire and filament as turn signal so you can use that to troubleshoot that tail light.
JeepFish1979 is offline
post #15 of 16 Old 11-30-2011, 08:52 PM Thread Starter
Baldum
1984 CJ8
I replaced the flasher with a transistor based one. Seems like everything is fixed, I just need to rewire a good amount of the tail lights because the PO was a butcher
Thanks for all the help, I would recommend replacing the thermal flasher to anyone with a CJ
Baldum is offline
Turn signal issues jeeptree2112 Jeep CJ Forum 3 09-30-2011 05:15 PM
Do rear side markers have to blink with turn signal? WoodyHD Jeep CJ Forum 5 03-03-2011 11:21 PM
Turn Signal Issues willidj Jeep CJ Forum 7 02-06-2011 02:16 PM
Left turn signal won't blink meater Jeep CJ Forum 5 12-21-2009 09:01 PM
Front Turn Signal Issues Jack-Jack Jeep CJ Forum 2 10-21-2005 10:00 AM
