Turn the key, won't turn over? - JeepForum.com
post #1 of 5 Old 03-11-2007, 08:38 AM Thread Starter
jelmore
1977 CJ7
Where to begin.
1980 CJ 7 4.2, 258 I6
New starter, good battery, won't turn over?
New plugs & distributor cap. Oil change.
!!!(Before the cap & plugs and wires she ran ok, just wouldn't start? We didn't change anything, and now it back fires, the problem has to be with that arear I suspect?)!!!
Turn the key and all you get is backfire from the carb? We have the firing order right. All I can think is that the cap is the wrong cap since the placement of the screws is different on the diagram I have than from our cap we bought from autozone? Could that cause backfire maybe?
Where to start to get her running from the pros... We're at the crossroads...
Basically what would be your next step, if she was yours. I'm folling the firing order and the diagrams perfectly.
Spray Painted 1977 CJ 7 258 4 spd tranny, that has been hacked up, which I am using as a daily driver, so time is of the essence.
jelmore is offline
post #2 of 5 Old 03-11-2007, 08:49 AM
Bard
I am going to say your timing is off as well. I would double check the cap to make sure it is on correctly. You didn't move the distributor at all did you? Also check you wires, could be some corrosion in them.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 5 Old 03-11-2007, 09:09 AM Thread Starter
jelmore
1977 CJ7
new wires...I think someone over the years has messed with the distributor honestly, cause we are dead on...Thanks Bard, I know, this is frustrating.
jelmore is offline
post #4 of 5 Old 03-11-2007, 11:03 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
Backfire or upfire (I just saw your other thread through the carb) as your cranking either means you put the dist on 180 out, or you've got the wires out of order; you're ignition is trying to fire a cylinder on the exhaust or intake stroke.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #5 of 5 Old 03-11-2007, 04:22 PM Thread Starter
jelmore
1977 CJ7
from other thread, I am good to go, I was 180 out! Turned the distributor around, worked perfect.
jelmore is offline
Turn down or not to turn down ref4ua Jeep CJ Forum 8 11-28-2008 10:11 PM
When I turn key, battery gauge pegs, but engine doesn't turn over part.changer Jeep CJ Forum 30 12-17-2007 04:34 PM
CJ5 won't even turn over know XJMudder Jeep CJ Forum 6 06-30-2007 07:10 PM
Turn signals turn on but dont blink JDGordon Jeep CJ Forum 6 02-27-2006 05:17 PM
Won't Turn Now Hale Jeep CJ Forum 0 05-05-2004 05:07 PM
