Turbocharged 258 - JeepForum.com
post #1 of 18 Old 07-31-2010, 01:10 PM Thread Starter
rustymudder
1982 CJ7
Turbocharged 258
I just acquired a Garrett T3 turbo for free from a friend. Would it be worth it to put this turbo on the ol' straight six or am I just crazy? Any ideas on how to make it work with my Howell tbi?
rustymudder is offline
post #2 of 18 Old 07-31-2010, 01:13 PM
Junkman
Go here and post you question lots of turbo knowledge
TheTurboForums - Index
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan
Junkman is offline
post #3 of 18 Old 07-31-2010, 06:52 PM
TJs83CJ7
Let us know what you find out. I would be interested to see how it comes out.
TJs83CJ7 is offline
post #4 of 18 Old 07-31-2010, 07:51 PM
xj5399
well its a lot more work then just bolting up the turbo... new intake manifold, exhaust manifold. all new cooling system, ecu, all for 20-30 hp probably
squeaks and rattles
If its not broken... It cant be fixed, so turn the radio up and enjoy the smooth melodies....
xj5399 is offline
post #5 of 18 Old 07-31-2010, 07:56 PM
benullman
1981 CJ7
But think of how COOL it would sound
If I could fit a compound turbo on the jeep like mydads 2008 F250 turbodiesel, I would do it in a heartbeat.
Ben
benullman is offline
post #6 of 18 Old 07-31-2010, 09:07 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
As great as the 258 is, I don't know if a typical 258 would be up to the task. I can understand the motivation to use a freebie, but I think in the end it's going to be a costly undertaking with minimal power gain.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #7 of 18 Old 07-31-2010, 09:12 PM
jasontx
1983 CJ7
True statement here....
I do not think it would be worth the $$$ and labor required and as someone stated the 258 may not be up to taking on some boost...
jasontx is offline
post #8 of 18 Old 07-31-2010, 11:09 PM
CrankyD
1983 CJ7
If the engine had a solid bottom end and good compression, then running the typical 1.5 BAR turbo setup would yield (10.71)(7)=74.97hp (thats at 75 hp@10 psi). I think it would be really worth it. It is a standard assumption that for every pound of turbo boost you will make 7 horsepower. The T3 would come on real early in a 4.2 I think the lack of RPM's would suit it well but you have to do the calculations on that. Turbos are fun... Do you have a TIG welder? I do! Lets have some fun!!!
CrankyD is offline
post #9 of 18 Old 07-31-2010, 11:29 PM
samuraisavr
Not poking at you, rustymudder, but I find good humor in some peoples thoughts of "bolting a turbo on". I think that the turbo thing is great and all, but unless a person has gobs of money, or the ability to do the fab work theirself, it shouldn't be attempted. A proper turbo setup is going to require a bigger fuel system (injectors, pump, regulator) Exhaust manifold, custom exhaust work (downpipe) wastegate (unless its internally gated) a bigger TB (otherwise the added boost is not flowing efficiently) some way to tune the ECU (likely a stand alone as AMC and mopar ECUs are not very receptive to custom tunes. This is not to say that a turbo 258 wouldn't be sick, but understand that just because you got the turbo itself free, theres LOTS that are needed to use that freebie.
Just
Empty
Every
Pocket
samuraisavr is offline
post #10 of 18 Old 07-31-2010, 11:30 PM
FamillyCJ7
1983 CJ7
Send the turbo to me and I'll put it to good use on my Mustang GT
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #11 of 18 Old 07-31-2010, 11:33 PM
FamillyCJ7
1983 CJ7
If I were to turbo my 258 I would do the junkyard TBI setup first. You don't have to keep changing out and burning chips anymore you can tune in real time and turn straight to the ect through the ALDL port
post #12 of 18 Old 07-31-2010, 11:43 PM
CrankyD
1983 CJ7
I would never attempt this setup with a carb, The factory throttle body should be fine as it would not be an "ultimate HP build" and would skew the TQ curve down lower if it were undersized. I believe that the factory system is a speed/density system so you have a point there (megasquirt!). A custom exhaust manifold is a must, I would use welded stainless. that leaves the fuel system, easy enough! I want to do it! Bring it over here!
CrankyD is offline
post #13 of 18 Old 08-01-2010, 11:11 AM
Junkman
Honestly Turbo charging is not that difficult. Even with a carb as long as it has the correct mods done to it its no big deal actually I think doing it with a carb is much easier, but thats just me. You can even use a mechanical fuel pump as long as its boost referenced. and you could do it with a stock exhaust manifold with a fabricated flange and downpipe. Now as far as what are the benefits? unless you have a correctly sized turbo that will spool at the correct rpm range that you will be working in (In the case of off roading it would have to be fairly low) you probably wouldnt see much benefit. It would help in high altitudes where the air is thin, but Im talking 10k or higher.
Ronald Reagan
Junkman is offline
post #14 of 18 Old 08-01-2010, 12:51 PM
wendell
1987 YJ Wrangler
If you want to run any kind of boost, you'll need forged internials. JP mag built a 4.0 stroked to a 5.0 with forced induction, it made 600 hp.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #15 of 18 Old 08-01-2010, 06:56 PM
FamillyCJ7
1983 CJ7
Where did you hear that from? I've seen stock geo's turboed. Do they come stock with forged internals? Nope. When turboing it's all about detonation. As long as you can add enough fuel to keep detonation down you can boost a motor. Of course the cast parts have there limits and will only hold up to so much power. Me and my friends built a turbo ecotec cavalier and were running 25lbs of boost on it all day, made a couple runs at 32lbs of boost and it still survived but if we would have kept that up it would have stressed the stock components too much and eventually blown.
Turbocharged 4 Cly??? poppatello Jeep CJ Forum 12 07-20-2009 10:13 AM
