Turbo 400 not shifting - JeepForum.com
post #1 of 21 Old 06-24-2011, 04:36 PM Thread Starter
Bigkuntree007
1981 CJ7
My 83 cj7 has a turbo 400 mated to an AMC 304ci V8 and it won't shift into 3rd gear. Seeing as how it only has 3 gears this is a problem. I think it's a vacuum leak but after I checked all the hoses all I can think that it might be is either the brake booster or the the part on the transmission where the vacuum line connects. Any ideas?
Bigkuntree007 is offline
post #2 of 21 Old 06-24-2011, 06:37 PM
jumbojeepman
1976 CJ7
Change your filter and fluid. Mine runs into this problem if the filter clogs up.
jumbojeepman is offline
post #3 of 21 Old 06-24-2011, 07:33 PM Thread Starter
Bigkuntree007
1981 CJ7
I don't know what the name of the module is on the side of the transmission is called that the vacuum line connects to. But I will definitely change my filter and fluid
post #4 of 21 Old 06-24-2011, 07:45 PM
Rollbar
1984 CJ8
Also when you change your filter, change the "O" ring on the drivers side front corner of the tranny when U drop the pan. There is a pick up tube and it just pulls straight down. When this cracks "O-ring" it will shift weird and slip into gear. Mine did the same thing and a .50 cent "O" ring saved the day along w/a new shift module.
<----Click
<---- Click
Rollbar is offline
post #5 of 21 Old 06-24-2011, 07:49 PM Thread Starter
Bigkuntree007
1981 CJ7
Is that what the vacuum hose connects to?
post #6 of 21 Old 06-24-2011, 08:05 PM
lucdog
lucdog's Avatar
1980 CJ5
I believe what you refering to is the modulator. This is were the vaccume connects to. Cheque the vaccume line from the
manifold to the tranny.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 21 Old 06-24-2011, 08:11 PM Thread Starter
Bigkuntree007
1981 CJ7
I chequed it bit no leaks
post #8 of 21 Old 06-24-2011, 08:19 PM
JeepHammer
Running On Empty...
1973 CJ5
One Quick Question,
When you stomped down on the throttle, did it go into 'Passing Gear', from 3rd to 2nd, or even 1st?
This is important, so think hard and let me know.
Anyway, if it didn't want to shift UP before failing, then pull the vacuum line off the vacuum modulator and put a clean vacuum line on the modulator and (Suck) on that line to see if the diaphragm is busted or not.
Take the Governor cover off and take the governor out, see if it's got some crap stuck in it that is keeping it from working...
Make sure your 'Kick Down' switch on the throttle pedal is working.
Without electronic kick down, the high gear clutch drum won't live long, and that means a rebuild.
Also a good idea to take the pan off and see if there is a bunch of clutch material in the pan.... change filter/fluid while you are there.
With TH 400s, when high gear goes out (Direct) it's usually kick-down not working or it's the governor not letting you get an 'Up Shift'.
If it's Kick Down, then the direct drive clutch pack is shot and there is NOTHING you can do about it without rebuilding the transmission.
That's about $250 for materials, rebuild kit, ect. and it's a pain in the butt to get out and back in... that's the bad news.
The good news is these things are so simple a monkey could rebuild them.
Tons of rebuild manuals and books out there, and as long as you follow the steps in the books, you will be fine.
Crud in the governor or the spool valve just inside the vacuum modulator port can be cleaned out, but if you are getting pieces of clutch large enough to jam up those spool valves, then start saving for a rebuild.
If it's just a popped vacuum modulator around $25 and half an hour fixes the problem.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 21 Old 06-24-2011, 08:39 PM Thread Starter
Bigkuntree007
1981 CJ7
I stomped down on it and all it does is stay in second gear and just rev up into a higher rpm while It goes faster. But it never shifts past second
post #10 of 21 Old 06-24-2011, 08:43 PM
lucdog
lucdog's Avatar
1980 CJ5
I think what JH wants you to do is, go drive it, easy on the gas, after it shifts to second gear, put the gas pedal to the floor. See if it shifts back down to first gear.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #11 of 21 Old 06-24-2011, 08:55 PM
Wrenches_00
Does reverse work? The direct clutch is used in both reverse and high (3rd) gears.
Adjust the kick down switch by pulling the arm all the way back toward the throttle pedal or linkage. It is on a ratchet of sorts and this is how it is adjusted.
Next push the throttle pedal to the floor and this adjusts the kick down. The kick down opens a solenoid valve that bleeds governor pressure and that will prevent a 2-3 shift. Also the kick down solenoid can be bad. Easy fix. Just drop the pan remove two screws and replace.
BTW, Kick down switch is best adjusted with the engine off. HTH
Wrenches_00 is offline
post #12 of 21 Old 06-24-2011, 09:06 PM
lucdog
lucdog's Avatar
1980 CJ5
If his TH400 is from "76" to "79" it doesn't use a TV cable. There's a elect. switch on the gas pedal. That works with WOT. Up shifts on my 400 work off vaccume. As far as I know.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #13 of 21 Old 06-24-2011, 09:25 PM
Wrenches_00
Bill
You are correct. The 400 doesn't use a TV cable. I simply told him how to adjust the electric kick down switch.
Up shifts occur when governor pressure overcomes vacuum modulator pressure. Downshifts work opposite of this. Kick down occurs because the kick down solenoid bleeds off governor pressure so to assist the vacuum modulator.
A Power brake in reverse will test the direct clutch and rear band. If the engine revs to the stall speed and stays there then the clutch and band are good. If not then rebuild is in order.
post #14 of 21 Old 06-24-2011, 09:44 PM Thread Starter
Bigkuntree007
1981 CJ7
I drove it. it does shift back into 1st gear but still doesn't go up to 3rd. I will have to try to test or adjust the kickdown
post #15 of 21 Old 06-24-2011, 09:58 PM
lucdog
lucdog's Avatar
1980 CJ5
Because your Jeep didn't originally come with a 304 and TH400, do you have the switch that connects to the upper part of the pedal, inside the tub? I ask because mine isn't connected and shifts fine. Wrenches00 seems to know whats up. He can probably help you more than me. And Earl, welcome to Jeep forums.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
