Which tune-up route should I go? - JeepForum.com
post #1 of 6 Old 09-03-2002, 11:19 PM Thread Starter
Nutz
I am starting to work on my 76 cj5's engine and it is in good shape, but I am trying to figure the best route for the distr, cap rotor, wires and plugs. What is the best setup for this engine, I want to make this engine hum when all is done. I am also willing to spend a little $ to make this roll. I have already changed the oil, oil filter, air filter. I have flushed the radiator and cleaned up the water pump, changed battery and wires. I have heard that there is a high energy distr. cap out there and I have called around to purchase and no one seems to know what is!? Any tune-up recommendations would be appreciated!! Nutz
Nutz is offline
post #2 of 6 Old 09-03-2002, 11:23 PM
JIM79CJ7
JIM79CJ7's Avatar
Put on an MSD 6A . if you've got alot of money to spend buy a Jacobs kit
JIM :{>
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #3 of 6 Old 09-04-2002, 06:37 AM
lynn
lynn's Avatar
Two methods come to mind.
First, GM HEI. Check here for more info:
www.geocities.com/jeeperaz/hei.htm
Second, Ford TFI is an option, a little less involved but also works well. Go to the forums at Off-road.com, go to the shoert wheelbase forum, and search on TFI upgrade. You might also try an internet search for TFI Upgrade.
HTH
Lynn
'05 LJ
lynn is offline
post #4 of 6 Old 09-04-2002, 03:07 PM Thread Starter
Nutz
Is the Gm HEI compatible w/ the 304 v8, that is what I have and I would also like to know can you purchase this setup over the counter or does it have to be through a junkyard? What exactly does this system entail- special wires and plugs or can I buy the iridium plugs and a quality set of wires.
Nutz is offline
post #5 of 6 Old 09-04-2002, 04:34 PM
CSP
It is not compatible with the V8 engine. You're stuck buying someone elses kit unless you are a competent machinist.
BTW, stick with standard plugs. The difference between a $1.99 plug and a $4.99 plug is only $3. Same thing with Jacobs. Sure they work good, but their customer service sucks when they fail. They charge people to troubleshoot and also charge for repairs and replacements. MSD usually troubleshoots/repairs/replaces problems with no charge to the customer. I like a product whose manufacturer stands behind. Jacobs is a joke in that aspect.
CSP is online now
post #6 of 6 Old 09-09-2002, 01:25 PM
twmattox
Check out the fire control 1000. It is a magnetic pickup replacement for the DuraSpark ignition...
twmattox is offline
81 CJ7 tune up--What's best? Drsafety Jeep CJ Forum 10 03-25-2009 05:46 AM
Emergency brake cable route Waltallshy Jeep CJ Forum 2 03-08-2009 10:27 PM
Can't route my new brake lines correctly! CJ4ever Jeep CJ Forum 4 03-01-2009 04:38 PM
cheapest axle route ugahopeful34 Jeep CJ Forum 2 11-27-2008 01:57 PM
86 cj bad engine what is the cheapest route? barry1me Jeep CJ Forum 13 03-24-2006 07:11 PM
