Tuffy Center Console Alternatives - JeepForum.com
post #1 of 8 Old 12-04-2002, 01:30 PM Thread Starter
TimR
Hi,
Anyone know of another company that produces a center console that has space for a head unit? The tuffy consoles are very nice, but i cannot see spending nearly $250 for a console.
Any one else out there produce a similar product? I suppose my only other option will be to fabricate on myself or dish out the money. I dont want a stereo in the dash and the stock location has already been covered by a switch panel anyways.
Thanks,
Tim R.
TimR is offline
post #2 of 8 Old 12-04-2002, 07:11 PM
knowlwk@snowhill.com
1980 CJ7
I just mounted a 20mm ammo can last weekend. I plan on building a mount inside it for a CD player, and adding some padding to the top for a good arm-rest. It isn't pretty, but "fits" the look of my jeep, and after a few modifications, it locks quite well, is water-tight, and only cost me $7.95 plus some spare nuts and bolts. I'm very happy with it, and can spend the spare $240 or some new 31x10.50 Mud retreads from High-tech.
knowlwk@snowhill.com is offline
post #3 of 8 Old 12-05-2002, 12:57 AM Thread Starter
TimR
Where did you get the ammo canister? Does any army surplus store carry them?Will you have access to your cd player while the lid is cloised? Post some pictures will its all bolted up, I would like to see the end product.
Thanks,
Tim R
TimR is offline
post #4 of 8 Old 12-05-2002, 01:33 AM
DaJeeper
Here's a link to one.
Here's a link to the same kind of setup with a pic:
Cheap Ammo Console Link
DaJeeper is offline
post #5 of 8 Old 12-05-2002, 08:05 AM
1980 CJ7
DaJeeper, that is probably one of the links I read before doing mine
TimR, most surplus stores probably will. Best bet is to take your jeep and do a test fit to be sure you like the size they stock, as there are several available. I first tried a 25mm can, that was the same length and depth, but about 2 inches wider. It fit well now, but would probably be too wide if I ever get around to a set of aftermarket seats.
As far as getting to the cd player with the can closed... I doubt it. It could probably be done, but would require some thought and work. I don't change stations often, or swap discs much, so it won't bother me. If you need easy radio access, best bet is to pony up the $250 for a Tuffy.
post #6 of 8 Old 12-06-2002, 03:18 AM
rednek
rednek's Avatar
open top for stereo
I fab'd two. One is for my cassette player and the other is for my CD changer. I took a Dremmel and cut the opening in the top and slid the stereo in. I drilled small holes in the bottom of the two to run the wires together to connect the CD changer. I then put in some egg shell foam andbuttoned up the top. Then the last step is to silicone any openings. The only disadvantage to this is that the faces are open to spills, but I like the results better than the $250 tuffy I had in my first Jeep (more money than smarts when I was single).
1980 CJ7
AMC 304 w/ Edelbrock 600cfm 4 bbl and home built snorkel
4 speed trans
3" Body lift
4" suspension lift
37 x 13 x 15 Boggers
15 x 10 Soft 5 rims
2 1/2" spacers
8000 lb Warn upright
1/4 turn hubs
Headers
CD changer and casette player w/ Orion amp and 10" bass tube, 2 - surface mount waterproof highs and 2 - 6 x 9 waterproof speakers
KC takedowns w/ homemade window mounts
Lock'd Rear
Flatfendered
Custom confederate flag paint job and DIXIE air horn
rednek is offline
post #7 of 8 Old 12-06-2002, 03:41 PM Thread Starter
TimR
Got any pictures?
Thanks,
Tim R
TimR is offline
post #8 of 8 Old 12-06-2002, 07:26 PM
rednek
rednek's Avatar
no pics yet
I am offshore so I wilkl have to wait to I get on land and get some pis.
1980 CJ7
4 speed trans
3" Body lift
4" suspension lift
15 x 10 Soft 5 rims
2 1/2" spacers
1/4 turn hubs
Headers
Lock'd Rear
Flatfendered
rednek is offline
Center Console jhebrew Jeep CJ Forum 6 12-22-2009 07:37 AM
Tuffy Center Console/ Marine Radio/Speakers lbijeep Jeep CJ Forum 10 05-21-2009 07:13 AM
Tuffy Security Console tomthbomb Jeep CJ Forum 9 09-01-2006 02:20 PM
Tuffy Console = kids in the back? Joe-n-TX Jeep CJ Forum 7 08-24-2006 05:58 PM
CD player in Tuffy console? johny1i Jeep CJ Forum 6 06-23-2003 11:13 AM
