-   -   Tubs from the Philippines (http://www.jeepforum.com/forum/f8/tubs-philippines-1480423/)
RommelJuan 02-17-2013 04:08 PM
Hi Everyone,
I'm Rommel Juan of MDJuan.
We make replacement tubs for the CJ7 and now the YJ as well.
I just wanted to ask if anyone here have used our tubs? And what has been your experience with them?
My purpose here is to hear your comments and suggestions so that we may improve our tubs to better serve the jeep community.
Cheers,
Rommel
roboto65 02-17-2013 05:31 PM
Oh this should be good hope it works :PopCorn:
I will say this I have not yet done a body I may have to in the future but from all I have read on here and around is that the bolt holes do not line up parts are misaligned. They can be improved but thats up to your company .
contdevelop 02-17-2013 05:37 PM
X2. i can't wait to hear some actual reviews. I to have heard the specs are crude at best.
Moparmandjh 02-17-2013 06:02 PM
Originally Posted by RommelJuan (Post 14985138)
Hi Everyone,
Cheers,
Rommel
Send me one and I'll do a thorough write up and review.......
BlkCJ7Laredo 02-17-2013 06:27 PM
Hi Rommel,
I have one of your tubs in my garage waiting for the final modifications needed so I can install on my CJ. Another member here, Keith460, has used one of your tubs for his restore also.
I am thinking that the main things I would jump on as a company if I were to try and improve the product would be:
1: Correct the rear body mount area as the splash shield interferes with fuel tank and must be changed and/or modified.
2: I would improve the stampings for the front floorboard section as the creases aren't very defined plus it appears to be two sections welded together where the original was one piece. Perhaps add the drain holes in the original factory locations as well.
3: I'd offer a CJ7 early and CJ7 late. The tubs up to '80 had smaller shifter hole in floor as all the tubs currently have and the "B" pillar wasn't added until 1981. The early version just had a sheet metal brace going back to the wheel well. So that means early would have smaller hole and not a full "B" pillar, and late would have the B pillar and larger shifter hole on the floor.
4: The baffles are missing on the tub in the rear wheel wells. These serve a few purposes such as to keep mud away from the taillight wiring and fuel filler, provide a mounting place for rollover and liquid check valves, and also is the rear mounting point for the roll bar.
5: Reinforcing rib and angled stamped square hole in the firewall for the throttle cable should be added. This would cover all models '76-86.
6: Closer measuring to be sure tubs are square and verify stamping molds to be sure items like hood will bolt up properly.
7: Improve primer process. Perhaps E-coating like the OEM's use currently.
Other than that it's great that someone is helping to keep our Jeeps alive by producing these parts. With a little more quality control and detail I think many more of these would be purchased as many people are afraid that they won't fit or require too much modification to fit their abilities currently. While the YJ tub conversion was a good option for a number of years now, we must remember that the newest YJ is now 18 years old so you face many of the same rust problems with them as you did an original CJ tub.
It's also good that licensed versions are available with the "Jeep" stamping and that it's in the correct place and font on the side panel.
mirage100 02-17-2013 07:11 PM
I would like to have one but I have heard about to many issues with them.
CherryCj7 02-17-2013 10:30 PM
Although I have not had any experience with your tubs, I have heard many complaints. I would like to suggest that you as a company take a CJ7 with a rusted out tub and use one of your tubs to replace it. This way, you would know first hand what all is wrong with your tubs. This way, you know exactly how far off different features are, or, what features could used re-enforced... I applaud your efforts to find problems and correct them. Good luck!
keith460 02-18-2013 08:53 AM
Hello Rommel
I used and currently have your CJ-7 tub as a replacement for my original OEM tub.
Will gladly make a write up of all the modifications that were necessary in order to fit onto a late model (82-86) frame. I have detailed pictures as well.
keith460 02-18-2013 04:20 PM
7 Attachment(s)
Firewall Section:
Firewall section could be improved with some additional holes and some of the factory locations for certain items for fitment like the heater/defrost assembly. It is hard to explain without your company actually having possession of the heating unit duct work and other various components that attach to the firewall from inside. One of the hardest things to do was to locate and drill the 3 mounting holes for the heating/defrost unit to the Repli-Tub firewall (Repli-Tub is what we refer to your units that come from the Philippines here on the Jeep Forum).
One of the first problems I had was fitting the heater fan motor through the hole that is already in place by your company. Because the top cowl section opening for the fresh air duct was not on centerline, off by a 1/4" from center, it forced me to convert to a popular upgrade of a larger fan motor. The hole is correct size and location but mounting the duct work on the upper plenum forced the assembly towards the passenger side by a 1/4". Therefore, a larger hole had to made slightly off center from existing hole.
http://i123.photobucket.com/albums/o...ubFitment7.jpg
There is also a bump or dimple in the OEM Jeep tub that allows a shaft from the duct work to clear the firewall after the heating/defrost unit is installed. I had to grind the end of the shaft in order for it to not make contact with the Repli-Tubs firewall once installed.
The throttle hole is missing and it is angled and a square hole. I drilled the hole in the factory location and then filed the corners to make square.
Once the square hole was made, I used a carriage bolt fitted with washers bolted in the hole and then carefully heated the sheet metal around to bend it to the proper angle.
It would be nice if the two strut brace brackets attached to the firewall upper section were in place. These are needed to provide additional support for the front grill.
A larger square hole opening is needed for the engine compartment electrical bulkhead connection to pass through on later model CJ's and YJ's.
There's no hole for the washer fluid hose or a hole for the nozzle on the top cowl section. Maybe not to important in states were it does not rain so much.
No battery tray mounting holes. 3ea. needed.
http://i123.photobucket.com/albums/o...epFirewall.jpg
http://i123.photobucket.com/albums/o.../firewall4.jpg
No bracket for the E brake assembly or Parking Brake.
No threaded backing plate for the Battery Tray.
Some more OEM factory Firewall Photos:
keith460 02-18-2013 04:21 PM
1 Attachment(s)
Top Cowl Section:
As noted, the opening for the fresh air vent was off center line by 1/4" towards the passenger side and there are holes missing for mounting the upper plenum duct work to the cowl and the washer fluid nozzle as well. Washer nozzle is on centerline of the cowl section.
http://i123.photobucket.com/albums/o...asherHole1.jpg
The holes are missing to mount the upper plenum of the heating unit to the top of the cowl. You do provide the holes for mounting the vent grill but the other holes for the plenum are not there and they are countersunk also from the factory.
http://i123.photobucket.com/albums/o...s/IMG_0152.jpg
Now for the bad, I mean really bad as it is one of the main reasons people cringe at the thought of purchasing a Repli-Tub.
The original OEM Jeep hoods with there crisp straight hood lines on the back and perfect curved contours to not match well to the cowl section front leading edge of the CJ series Repli-Tubs. MD Juan really needs to improve on this area and should make it one of their top priority's to see that it is done.
The edge is wavy and not straight and it would have taken to much body filler to correct and no one would want to do that and risk having the filler pop off after primer and paint.
The pictures speak for themselves.
http://i123.photobucket.com/albums/o...int-Body11.jpg
http://i123.photobucket.com/albums/o...aint-Body8.jpg
http://i123.photobucket.com/albums/o...aint-Body7.jpg
http://i123.photobucket.com/albums/o...aint-Body6.jpg
I don't have a good photo of the steel dash that is supplied with the Repli-Tubs only because I removed it knowing I was not going to use it.
Once removed, 80% of the holes MD Juan drilled Do not match the factory dash panels and most had to be filled in with weld and then ground flat again.
I also used factory type weld tabs in both 5/16-18 and 3/8-16 thread where needed and borrowed a spot welder to attach them.
Floor and Inner Tub Section:
Factory.
http://i123.photobucket.com/albums/o...t/IMG_0201.jpg
Repli-Tub.
http://i123.photobucket.com/albums/o...bFitment10.jpg
keith460 02-18-2013 04:22 PM
Body Mounts:
Future Comments
keith460 02-18-2013 04:24 PM
Mounting Holes and Brackets:
Future comments
RommelJuan 02-19-2013 12:26 AM
that's great Kieth. We will look forward to that.
Originally Posted by keith460 (Post 14988841)
Hello Rommel
RidgeRat 02-19-2013 06:36 PM
Rommel, I think it's great on your part to be proactive in improving your product and going right to the source of the most passionate CJ'ers I can think of to look for ways to improve. Good on ya.
The time now is 06:56 AM.
