Quantcast Tubes, CJ AMC 20 vs FSJ AMC 20 - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep CJ Forum > Tubes, CJ AMC 20 vs FSJ AMC 20
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 10-23-2009, 02:06 PM   #1
Sundowners
Does anyone know the actual size of the axle tubes that Jeep used on the FSJ AMC 20? I have heard that they are bigger than the CJ AMC 20 but I could not find any actual numbers? I'm looking for the dia and wall thickness of the tubes of the FSJ AMC 20 and the CJ AMC 20 so I can compare the two.
Thanks,
Brian
Sundowners is online now   Reply With Quote
Old 10-24-2009, 10:33 PM   #2
78treehugger
Lost and Not Found
1980 CJ7
Not sure of the diameter but I believe they are the same diameter just that the FSJ is a thicker wall.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
http://emptypocketsoffroad.org/
78treehugger is offline   Reply With Quote
Old 10-25-2009, 08:16 AM   #3
tahoe wheelers
Dont know the diameters either, but the AMC 20 FSJ comes with factory one piece axles and will also be a 6 lug bolt pattern.
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way.
www.therockgods.com
www.reno4x4.com
tahoe wheelers is offline   Reply With Quote
Old 10-27-2009, 12:24 PM   #4
Sundowners
Thanks guys, It would make more sense that they were the same OD just different walls, That way they (AMC) only has to have one pumpkin casting.
B
Old 10-27-2009, 12:55 PM   #5
PavementPounder
Cool as Ice...
PavementPounder's Avatar
They aren't the same OD. The FSJ 20 has the same OD as the FSJ D44. The FSJ housing also has the tubes pressed-in farther. I believe I still have one of each housing and both have been gutted, so I may be able to get them both over to the chop saw at the shop to get some real numbers.
This is how NAXJA Midwest Chapter elected officials like to treat their resident users and former multi-year supporters.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline   Reply With Quote
Old 10-27-2009, 01:23 PM   #6
Sundowners
Thanks PavementPounder, Always a big help!
Thanks,
B
Old 11-18-2009, 12:45 PM   #7
sdozzi
1979 CJ7
The FSJ AMC 20 has a diameter of 2.75" it is the same as the model 44 on a FSJ. The U bolts from a CJ will not work on the FSJ axle. Can't get the wall thickness but I do know the axle shafts are different. If you try to put CJ axles in the FSJ AMC 20 you need different size bearings. Also the bolt pattern that holdes the backing plate on are different. It is a stronger axle then the stock CJ.
sdozzi is offline   Reply With Quote
Old 11-18-2009, 12:56 PM   #8
CSP
Wish I had seen this thread earlier. This number ^^^^^ is correct. The CJ version is 2-5/8".
CSP is offline   Reply With Quote
Glock Forum
