tube fender gurus: help - JeepForum.com
post #1 of 6 Old 09-25-2011, 06:54 PM Thread Starter
monsonman
monsonman's Avatar
Okay so finally mustered up the courage to take the saw to the cj. I'm in the process of installing a set of poison spider tube fenders. I made the cuts to the outer fender that I traced from the instructions. But, the outer fender is still connected To the inner by what I think is some sort of seam that runs from the top of the the fender to the bottom. What else needs to be done/cut/ripped/destroyed in order to free up the inner fender? any help is greatly appreciated as always.
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #2 of 6 Old 09-25-2011, 08:32 PM Thread Starter
monsonman
monsonman's Avatar
the seam i am referring to is illustrated is RED in this hi-definition rendering.
'98 TJ- build:
post #3 of 6 Old 09-26-2011, 06:43 AM
CSP
The inner fender is spot welded to the outer. Look carefully and you can see the spots which can be drilled out.
CSP is online now
post #4 of 6 Old 09-26-2011, 06:55 AM
bkeese
1949 CJ3A
I thought Poison Spyder tube fenders used the inner fenders as-is. UNless they have changed you cut the fender, leave the inner and attach the Poison Syder fender to the existing fender. That was the reason I walked away from them.
1985 CJ7 - total customization underway, Sublime green and Plum crazy purple, Ford 9", 258 w/ Holley 475
1985,93 CJ7,YJ - L98 TPI Vette motor, Atlas twin stick, Dana 60s front and rear, Arbs, 39.5 Swampers
bkeese is offline
post #5 of 6 Old 09-26-2011, 09:27 AM Thread Starter
monsonman
monsonman's Avatar
you are right, they do use the current inner fender. I'm trying to figure out how to remove the outer fender from the inner...
'98 TJ- build:
post #6 of 6 Old 09-26-2011, 01:35 PM
bkeese
1949 CJ3A
Then what? You won't be able to attach the Poison Spyder tube fender to the inner fenders, will you? I don't think there is an overlap.
As for removing, they make a spot weld cutter. It mounts in a drill and basically cuts a 1/4" circle around the spot weld. Then a little persuasion with a hammer and chisle and presto 2 pieces. Google it, I got mine from Eastwood.
bkeese is offline
