Tub removed..now what? - JeepForum.com
post #1 of 8 Old 02-29-2012, 12:41 PM Thread Starter
usmarine3521
Alrighty. I've got the tub removed off my 84 cj7. I am planning on a restore but with a budget. I want to re use anything I can, just want to make it look better and cleaner. I'm looking at my frame and it's not rusted as bad as i expected. It looks to be surface rust mostly.
Attachment 354997
I was planning on taking a wire wheel to the frame and take off all of this dirt and rust. After that I wanted to prep it and use Chassis Saver.
Next I have been looking at the body mounts and the welds seem to have quite a bit of rust. It also seems to be surface rust but I am unsure. Should I grind them off, clean the area, and re-weld it on?
Another question I have is I noticed a lot of my fuel lines are rubber hoses. From the tank to the electric pump and even around the carb. What can I do and use to eliminate the rubber hoses?
Basically am I going the right route with the frame and what other things should I be looking at while I have the frame exposed?
usmarine3521 is offline
post #2 of 8 Old 02-29-2012, 12:58 PM
mopar346
Well I would have the frame blastred or dipped if at all possible, quicker and better and it will tell you EXACTLY what you have to work with. I have seen too many people get hundreds or thousands into a project to find out it is non-repairable in the end and all that money is lost. There apears to be more than surface from the pictures, but still looks pretty good and definitely repairable. For instance the body mount hole in the first picture is rusted out, it should look more like the one in the second picture. Once completely clean, I would coat it with POR 15 and then repair as needed and recoat the repaired areas. The factory welds I would simply clean up, if I had a concern I would add additional welded as I felt was needed.
As for the fuel system, the rubber on top of the tank looks factory the other is obviously PO engineering and although serviceable I would clean it up while you have easy access and use steel lines with the correct fittings where ever possible and steel braided if I felt I needed the flexibility. I usually bend my own out of long lengths of tubing. I will admit to doing work like what you have in a pinch and then never going back to fix it.
I believe you are on the right track, tearing it down to it's roots, accessing what you have, asking questions and making repairs.
mopar346 is offline
post #3 of 8 Old 02-29-2012, 04:49 PM Thread Starter
usmarine3521
Thank you for your response. I have thought about getting it dipped, only problem is the closest place I can find is 4 hrs away from me. I don't have the transportation to get it there. So what can I do instead of dipping it, stick to cleaning the frame up as best I can and use POR-15 or something of that nature?
post #4 of 8 Old 02-29-2012, 07:59 PM Thread Starter
usmarine3521
Also. If i want to replace all my
Body mounts, is there anywhere to buy new ones that just weld back on?
post #5 of 8 Old 02-29-2012, 08:32 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
If you're looking to save money, then you're going to have to put a lot of your own time in to the project. I would hit the whole frame with a twisted steel wire wheel. That should help you determine the extent of the rust damage, and then you'll know if anything needs to be repaired before painting.
One neat thing is to coat the inside of the frame with paint to help resist internal rusting. If you're planning on taking the frame totally off, then you could paint the inside by pouring in some paint and moving the frame around to work the paint all along the inside surfaces.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #6 of 8 Old 02-29-2012, 08:46 PM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
I'm w/mopar346 100%. Rent a U-haul for the day, steal a picup truck. Had mine blasted and p-coated for $600, but that's in the sticks of Pa. I know you have stricter enviro laws.
The hard part for you, is finding a closer sandblaster. See who makes dirt track car frames, aerospace manu-fabbers, race engine shops etc. Anybody that does powdercoating has/knows a sandblaster. Make lots of calls, knock on doors...Good Luck!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #7 of 8 Old 02-29-2012, 09:00 PM
mopar346
If blasting or dipping is not an option, then wire wheel is the wayu to go, but it is a lot of work to do to any real effect. But if that's what you got it will work. I believe you can buy the mounts that weld on but some are part of the frame and will have to be repaired with plate steel, the trick will be cutting back to good metal and centering it properly. Painting the inside is a great idea and to roll the paint in is the best way, it will waste some but it will get into every nook and cranny that way. You will also need to use a paint that will stick to rust, again like POR15, since you aren't gonna be able to clean inside the frame.
First order of business though is to strip it down and clean it and make sure of what you have and what is in need of repair. Once that is done the rest will be down hill and rewarding.
Good luck.
Careful your character's showing
mopar346 is offline
post #8 of 8 Old 02-29-2012, 09:02 PM
VACJ7
VACJ7's Avatar
Yes, they sell replacement mounts that weld on. But if it is just the top (hole) a lot of guys will just cut it out and weld in a patch and drill new hole. You can also replace that rear crossmember.
'84 CJ-7 |
VACJ7 is offline
