tub mount bushings - Page 2 - JeepForum.com
post #16 of 22 Old 01-20-2013, 08:04 AM
mirage100
1976 CJ7
Originally Posted by keith460 View Post
Are the bushings rubber with steel tubes or poly type?
If you have OEM type rubber ones then you will need to cut down the steel tubes except for two. The two that don't get cut down go to the front Toe Board mount just under the firewall and use the largest rubber isolator out of the kit to bolt up at the bottom. All other bushing tubes get cut down to within a 1/4" recessed when the bottom rubber isolators are in place so that they can compress down to the 2" washers when tightening them down.
So does that mean if I get like the Daystar kit I don't have to cut ant down?
mirage100 is offline
post #17 of 22 Old 01-20-2013, 10:26 AM
keith460
Jeep. There's Only One
keith460's Avatar
The poly bushing body mounts do not include or use the steel tubes since they are rigid enough as they are. Your going to feel more drive train and road vibrations with aftermarket poly bushings vs. OEM type rubber bushings.
1984 CJ-7 Renegade
keith460 is offline
post #18 of 22 Old 01-20-2013, 12:32 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
Also remember that the replacement rubber OEM type mount kits do not include the grille mount.
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #19 of 22 Old 01-20-2013, 01:22 PM
JrTjK
1978 FSJ Wagoneer
*at the present time
JrTjK is offline
post #20 of 22 Old 11-28-2014, 08:23 AM
2001WJv8
2015 WK
I used an angle grinder with cutoff wheel, went through the sleeves like nothing. Really wouldn't have been a bad job except that I had already put them in before reading this thread ... so I had to do it all again
also, my kit included the front bushing
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #21 of 22 Old 01-26-2015, 07:12 AM
Dborns
I'm using a Daystar kit. They all have the centering ring you speak of, but only one large washer for each mount, so not two on each end of the mount. They did not come with any sleeves. I'll buy the bolts but I'll take a closer look at the instructions before I install. They have pics of each mount, so I'll see if it looks like there's a sleeve installed.
I get the concept without the sleeve you're tightening two soft objects down.
Dborns is offline
post #22 of 22 Old 01-26-2015, 07:19 AM
Mike Romain
The factory crush sleeves have the top washer formed to them so you only need the one washer on the bottom.
http://m.quadratec.com/products/prod...pid=55008+1000
Mike
Mike Romain is offline
Which body mount bushings? kmm Jeep CJ Forum 1 11-28-2009 03:21 PM
79 cj7 body mount bushings AZCJ-7 Jeep CJ Forum 2 06-26-2009 09:57 PM
motor mount bushings Fabian15 Jeep CJ Forum 3 06-13-2009 11:30 PM
rubber mount bushings hold24 Jeep CJ Forum 21 04-06-2009 09:20 AM
body mount bushings durdenclub Jeep CJ Forum 8 07-22-2005 12:31 PM
