tub mount bushings - JeepForum.com
post #1 of 22 Old 07-30-2010, 02:57 PM Thread Starter
somdfisher
1981 CJ7
tub mount bushings
I bought new bushings for my 7 and I was wondering how people installed them.
O|||||O 1981 CJ7, 258, 4 speed..If it ain't cut, it ain't custom.
somdfisher is offline
post #2 of 22 Old 07-30-2010, 03:19 PM
keith460
Jeep. There's Only One
keith460's Avatar
Are the bushings rubber with steel tubes or poly type?
If you have OEM type rubber ones then you will need to cut down the steel tubes except for two. The two that don't get cut down go to the front Toe Board mount just under the firewall and use the largest rubber isolator out of the kit to bolt up at the bottom. All other bushing tubes get cut down to within a 1/4" recessed when the bottom rubber isolators are in place so that they can compress down to the 2" washers when tightening them down.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 22 Old 07-30-2010, 05:09 PM Thread Starter
somdfisher
1981 CJ7
I have the rubber ones. They have to be cut down a 1/4"? Are the bushings supposed to compress when tighted?
Thanks for the help, the PO used plastic pucks for most of it so I have nothing to compare to.
post #4 of 22 Old 07-30-2010, 05:10 PM Thread Starter
somdfisher
1981 CJ7
post #5 of 22 Old 07-30-2010, 05:17 PM
keith460
keith460's Avatar
Cut down what ever it takes to get 2ea. of length "A" and 8ea. of length "B". Using a pipe cutter is best and yes the rubber bushing should compress some until the proper torque of 24 ft/lbs is obtained. 36 ft/lbs for Support Bracket-to-Rear Floor Pan which has no bushing.
1984 CJ-7 Renegade
keith460 is offline
post #6 of 22 Old 07-30-2010, 06:48 PM
Lordwrench
1978 CJ7
Great info,Keith
Lordwrench is offline
post #7 of 22 Old 07-30-2010, 07:00 PM
yellow85cj
Here's what it looked like when I used Keiths' measurement of 1 1/4" for the eight (As close as I could get it. Should be flush with the bottom of the bushing) . And what it looked like when I mounted it on my replacement frame mount (before I welded it to the frame). The frame mount I have is 1/4", the OEM is not quite that thick.
Currently in pieces - all of them
yellow85cj is online now
post #8 of 22 Old 07-30-2010, 07:53 PM
keith460
keith460's Avatar
Just like yellow85cj has his shown on the first two pictures is how they should end up. Once the large 2" flat washer is mounted to the bottom of the bushings, it will start to compress the rubber some until 24 ft/lbs of torque is obtained. That is enough torque to compress the rubber bushings and make a solid foundation for your tub to frame mounting.
I know a lot of guys make this mistake by not cutting down the steel tubes to proper length and then they wonder why the tub is still lose on the frame and makes a bunch of noises when hitting bumps and what not.
1984 CJ-7 Renegade
keith460 is offline
post #9 of 22 Old 07-30-2010, 08:07 PM
Splinter
1980 CJ5
Great info x 2
What would change when applying this info to a CJ5??
Splinter is offline
post #10 of 22 Old 07-30-2010, 08:12 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Good stuff!! I linked this to the FAQ Sticky for future reference!!
BESRK is offline
post #11 of 22 Old 08-08-2010, 02:47 PM
Splinter
1980 CJ5
On my CJ5 the large rubber bushing shown in position 2 was on position 7. (rear mount) It appears to me that the large bushing has to go here because of the large hole in the frame bracket. The smaller bushing, sleeve and bolt go in from the bottom.
This picture from another build also shows the large size of the frame bracket. Can someone clarify this for me?
Splinter is offline
post #12 of 22 Old 08-08-2010, 05:27 PM
yellow85cj
All of the holes for the bushings should be the same size. All go in from the top.
In pics 1 & 2 the holes appear to have just rusted out. Time for some repair or a new rear cross member.
post #13 of 22 Old 08-08-2010, 05:36 PM Thread Starter
somdfisher
1981 CJ7
The holes just be a touch bigger than 1-1/4" to fit right. I had to fix a few rusted out mounts.
My last questions besides my closing comment, the bigger part goes in the top and the sleeve goes in the top as well right? Then use a washer on the bottom with the larger inner diameter part correct?
And cutting the sleeves with a pipe cutter is no walk in the park.
post #14 of 22 Old 08-08-2010, 07:14 PM
Splinter
1980 CJ5
Heh, heh, bin there, I just scored it with a tubing cutter that opens to one inch and then used a hacksaw.
Splinter is offline
post #15 of 22 Old 08-31-2010, 06:39 PM
Agar426
1974 CJ6
There isn't by any chance one of these diagrams for the pre-'76 CJ's?
Agar426 is offline
Which body mount bushings? kmm Jeep CJ Forum 1 11-28-2009 03:21 PM
79 cj7 body mount bushings AZCJ-7 Jeep CJ Forum 2 06-26-2009 09:57 PM
motor mount bushings Fabian15 Jeep CJ Forum 3 06-13-2009 11:30 PM
rubber mount bushings hold24 Jeep CJ Forum 21 04-06-2009 09:20 AM
body mount bushings durdenclub Jeep CJ Forum 8 07-22-2005 12:31 PM
