Tub To Frame Mount - JeepForum.com
post #1 of 10 Old 03-09-2007, 05:57 PM Thread Starter
WLO215
Tub To Frame Mount
I Am Currently Restoring My 81 Cj7 And I Need To Replace The Front Most Tub To Frame Mount. This Is The Part That Is Attached To The Tub And Is Where The Nut Is. I Have No Idea What It Is Called Or Where I Can Get One Any Ideas....i Also Have Pictures If It Helps....thanks
WLO215 is offline
post #2 of 10 Old 03-09-2007, 06:07 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
the nut is on top of the ''shelf''.If your talking about the ones behind the front tires..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #3 of 10 Old 03-09-2007, 06:15 PM
Bard
Post some pics, or a link. I might have some that are good if I can cut them off.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #4 of 10 Old 03-09-2007, 06:37 PM Thread Starter
WLO215
I Currently Can Not Post Pics....can I Email Them .....
WLO215 is offline
post #5 of 10 Old 03-09-2007, 06:40 PM
Bard
Post the link from photobucket or something here
Bard is offline
post #6 of 10 Old 03-09-2007, 07:09 PM Thread Starter
WLO215
WLO215 is offline
post #7 of 10 Old 03-09-2007, 07:33 PM
Bard
What side you need? Do you have access to a welder? Might be easier to have someone fab it close to you
Bard is offline
post #8 of 10 Old 03-09-2007, 08:59 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
I'm sorry I miss read your question,..I had to fab up a plate to run under that,but yours is way to gone to just re-do..
:hahaha: yj
post #9 of 10 Old 03-09-2007, 09:12 PM Thread Starter
WLO215
Pass. Side....i Made One For The Driverside Thought Might Be Quicker To Find One....
WLO215 is offline
post #10 of 10 Old 03-10-2007, 01:29 AM
jeepskate
I think it's referred to as a tow board...I believe Classic Enterprises carries them. Yup...$55.00 http://www.classicent.com/jeep.php#pricing
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
Roll cage to frame mount 78treehugger Jeep CJ Forum 12 02-05-2010 06:48 PM
Which frame mount do I swap? BG33 Jeep CJ Forum 0 10-22-2009 06:45 PM
Frame body mount ??'s danheit Jeep CJ Forum 3 12-28-2008 05:12 PM
MORE V8 mount guys... how far forward did you mount your frame brackets? Aaroneous Jeep CJ Forum 11 05-06-2008 07:10 PM
CJ-7 Grille - Frame Mount??... dvzant Jeep CJ Forum 2 03-20-2007 06:30 PM
