tub fixin' (pics) - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > tub fixin' (pics)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 02-10-2008, 03:39 PM   #1
jagerlager
1979 CJ7
tub fixin' (pics)
1tub-work-007.jpgHey guys...
Finally started to fix up the tub. I decided to replace bad spots with new steel.
Since all the spots I need to fix are where panels meet floor etc... It seems its going to be a mess. I thought of bending 16 ga. angle and spot welding to the floor panels and then spot welding repaired side panels to that. Do I need to go that far? is this tub too far gone?
I fabricated some new front floor supports, and cut out and made a new floor patch, and attempted to weld it in. It seems tacking works well, but some areas of existing floor are too thin and it blows right through. I thought I cut back to good metal.
any advice?
perhaps you can point me in a more successful direction.
Thanks!
1979 cj-7
t-150 transmission
model 20 transfer case
dana 30 front axle - amc 20 rear axle
in line six 258
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote."
[URL="http://www.jeepforum.com/forum/showthread.php?t=473436"]Frame repair thread[/URL]
[URL="http://www.jeepforum.com/forum/showthread.php?t=518603"]Tub repair thread[/URL]
[URL="http://www.jeepforum.com/forum/showthread.php?t=562223"][U]Assembly thread[/U][/URL]
jagerlager is offline   Reply With Quote
Unread 02-10-2008, 03:40 PM   #2
jagerlager
1979 CJ7
1979 cj-7
t-150 transmission
in line six 258
Unread 02-10-2008, 03:54 PM   #3
roundlitefan
Certainly not an expert, since the only welding I have ever done is TIG and SMAW, and no sheet metal experience, but one rule is non-flexible.
You can't weld air.
It looks like some of your patch may be cut too small, and you have some pretty large air gaps there that you are trying to fill with rod. I can't tell for sure from the pics, but that is my best guess.
Again, no body welding experience, so take it with a grain of salt.
roundlitefan is offline   Reply With Quote
Unread 02-10-2008, 03:55 PM   #4
Bard
Well, tub does seem kinda rusty, still can see the rot in the pics where it was missed or just overshot with the blaster. As for welding in panels, you should be able to adjust your heat and feed to burn a little lower and slower. If the weld blows through like the pics, well the metal isn't very good to begin with and the heat is finding the pockets where it can go thru. Could be alot of it due to the condition of the tub.
Edit - when doing patches, do complete so they mount easier. Example is a floor panel, i have seen more 8x16 sections and it only enforces that section, really defeats the purpose of fixing it. Just do the whole floor panel and make it stronger.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Unread 02-10-2008, 04:18 PM   #5
Fatman
2008 CJ7
I gotta hand it to ya, I went 1/4" overlap and still had a time.
Try to slow your wire down just a bit and work int the pool. stop and make tacks every three inches, then go back and do every two and the one inch. Sheet is hard !
Fatman is offline   Reply With Quote
Unread 02-10-2008, 05:51 PM   #6
Jimthejeepman1
1978 CJ7
When your welding two metals together and you have either really thin metals or a gap your dealing with, use a thick piece of copper or brass on the back side of the weld. The weld won't stick to the copper or brass, and it will pull some of the heat away which will result in blowing less holes in the steel and burn through. This method works really well when you are tackwelding or stitch welding pieces together, because it lets you build up the thin areas with weld.
Jimthejeepman1 is offline   Reply With Quote
Unread 02-16-2008, 08:39 PM   #7
jagerlager
1979 CJ7
Thanks for the tips!
A little more progress (if ya can call it that). Very little fab experience, very little welding experience... Learning as I go. I plan to blast again. Couldnt find a brake out here in the sticks so I welded an angle onto the 16 ga for the panel repair. I like how it turned out. This is all a bit messy looking but should be very structurally sound and in the end grinding, blasting, body filler and seam sealer should clean it up.
2tub-work-029.jpg   2tub-work-030.jpg   2tub-work-031.jpg   2tub-work-033.jpg   2tub-work-036.jpg
1979 cj-7
t-150 transmission
in line six 258
Unread 02-16-2008, 08:40 PM   #8
jagerlager
1979 CJ7
one more picture.
1979 cj-7
t-150 transmission
in line six 258
Unread 02-16-2008, 09:12 PM   #9
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
My tub was much worse. Keep on rocking with that one.
Pacfanweb is offline   Reply With Quote
Unread 03-12-2008, 08:17 PM   #10
jagerlager
1979 CJ7
Been moving right along. Learning how to make better welds.
Thanks to you guys for the tips!
I'm quite a bit furthur along at this point. I'll try to get the posts caught up.
Heres the first batch.
I used 3/4" angle to connect the patches to existing floor panels.
I went back after tacking and slowly welded solid then ground... not bad results, will need filler.
Jig saw to cut the patches. cut wheel to cut out bad areas.
I decided to save the wheel well profile, and weld it back to the patch. I was amazed it worked out.
3tub-work-007.jpg   3tub-work-017.jpg   3tub-work-006.jpg   3tub-work-022.jpg   3tub-work-023.jpg
1979 cj-7
t-150 transmission
in line six 258
Unread 03-12-2008, 08:27 PM   #11
jagerlager
1979 CJ7
A few more.
I'm patching as I go no big over all plan which is probably a bad Idea.... but Its working out so...
Glad I chose this route over fiberglass, although it is a challenge, and takes forever for me.
3tub-work-023.jpg   3tub-work-026.jpg   4tub-workmarch1-002.jpg   4tub-workmarch1-003.jpg   4tub-workmarch1-014.jpg
1979 cj-7
t-150 transmission
in line six 258
Unread 03-12-2008, 08:29 PM   #12
jagerlager
1979 CJ7
a couple more.............
1979 cj-7
t-150 transmission
in line six 258
Unread 03-12-2008, 08:44 PM   #13
jagerlager
1979 CJ7
new Body mounts.
Several measurements for location.
3/4" angle iron cradle, two ply 16 ga. with nut welded on... Might work.
4tub-workmarch1-027.jpg   4tub-workmarch1-028.jpg   4tub-workmarch1-031.jpg   4tub-workmarch1-037.jpg   4tub-workmarch1-038.jpg
1979 cj-7
t-150 transmission
in line six 258
Unread 03-12-2008, 11:17 PM   #14
coas
Great job!!
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost.
My esnips folders:Jeep Jeep Transmissions
coas is offline   Reply With Quote
Unread 03-13-2008, 08:08 AM   #15
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
I'm about to start repairing my body, I will be thrilled if my welds come out even close..... Great Job
SlikRic is offline   Reply With Quote
