Trying to tune 304 V8.. - Page 2 - JeepForum.com
post #16 of 33 Old 10-06-2013, 09:43 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The standard setup is to have the wix-type bypass filter between the carb and a mechanical pump.
I'm not sure what the best setup is for an electrical pump, but I suspect you may be loosing too much pressure under load by having the bypass filter so far from the carb. The fuel will take the path of least resistance, which may be the return line in your current setup.
Matt
Matt1981CJ7 is offline
post #17 of 33 Old 10-06-2013, 10:42 AM Thread Starter
stephenspann27
2014 WK
My setup doesn't have a return line. I can watch the fuel flow through the glass filter by the carb. Before replacing the clogged filter the glass one would barely stay half full. With that problem corrected the glass filter is always full even at high rpm.
2014 Overland JGC. Hemi/8 spd.
1975 CJ5 304 V8/3spd
stephenspann27 is offline
post #18 of 33 Old 10-06-2013, 10:44 AM Thread Starter
stephenspann27
2014 WK
I am starting to wonder if I have a bent pushrod or burned valve. If a new plug wires and icm don't fix the issue ill do a compression test and pull the valve covers
post #19 of 33 Old 10-06-2013, 10:53 AM
LumpyGrits
That filter by it's design, regulates psi.
The smaller outlet port(return line)must be installed at the 12 o'clock position.
I would also check to see if you have the carb float set 'rite'.
Make sure your carb is 'rite' BEFORE you start throw'n $$$ at it..........
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #20 of 33 Old 10-06-2013, 11:46 AM Thread Starter
stephenspann27
2014 WK
All measurements aside, the float is basically supposed to be level when the needs seats correct? I'll get another wix filter and get it back in place.
post #21 of 33 Old 10-06-2013, 04:55 PM Thread Starter
stephenspann27
2014 WK
ok.. so I went wheeling.. for about 4 hours. I replaced the wix filter. Something is definitely up with the fuel delivery. I am back down to 1.5 psi. I'll find a replacement pump and go form there. It seems to obviously not be getting enough fuel.. surges on the hwy.. it will idle.. but not run under a load.
post #22 of 33 Old 10-07-2013, 10:39 PM Thread Starter
stephenspann27
2014 WK
Replaced the pump today. Definitely not a fuel supply problem. Pressure is good. I also took the top off the carb to find the bowl full. With the key on (pump running) if I press down on the float, fuel comes flying out. A guy on another forum somewhat has me convinced it's a stretched timing chain.. that would explain the timing mark that seems to be off. Before looking into that, I want to replace the power valve. I know mine is dual stage. Does anyone know what the specs are on the stock valve? Or should I drive it with a vacuum gauge attached and try to get a cruise reading?
post #23 of 33 Old 10-08-2013, 06:08 AM
Scoutski
Sounds like you need to do some basic troubleshooting: I would start with a compression test, this would eliminate a suspect burnt valve. The timing chain is a good bet, but it could also be a worn out camshaft bent pushrod,weak lifter. Are you shure that there isn't a crossed plug wire, or a crack in the distributor cap? Check the resistance of the plug wires. There is a posibility that it isn't a fuel problem afterall. Good luck!
Scoutski is offline
post #24 of 33 Old 10-08-2013, 12:48 PM
cj5752
1975 CJ5
Are you running the stock prestolite ign or has it been changed?
cj5752 is offline
post #25 of 33 Old 10-08-2013, 07:54 PM Thread Starter
stephenspann27
2014 WK
I agree. I have new wires arriving tomorrow. It still have the motorcraft ignition. The cab looks newish, I replaced the coil, rotor looks good. But ya.. I haven't ruled out much so far.
post #26 of 33 Old 10-08-2013, 08:31 PM Thread Starter
stephenspann27
2014 WK
I verified that the spark plugs are wired correctly. I will be posting a video in the next few minutes of me rotating the crank and watching the rotor. I would have to turn the crank 90 degrees before the rotor ever moved.
post #27 of 33 Old 10-08-2013, 08:47 PM Thread Starter
stephenspann27
2014 WK
It's hard to see how far I'm moving the crank. I'm going from 12 o click to 3 o clock before the rotor moves any. I wouldn't think this is normal? If it's not the chain maybe it's a worn distributor gear?
https://www.dropbox.com/s/pei0qtm070...008_212642.mp4
post #28 of 33 Old 10-08-2013, 09:48 PM
MoneypitCJ5
1977 CJ5
I know I'm just jumping in here, but the rotor should turn half of what the crank does. It takes 720 degrees of crank rotation for the rotor to turn 360.
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #29 of 33 Old 10-08-2013, 09:55 PM Thread Starter
stephenspann27
2014 WK
I hear ya.. but I get zero movement out of the thing when I change directions until I've turned the crank almost 90 degrees. I think I need to pull the dist. and check the teeth.
post #30 of 33 Old 10-08-2013, 10:22 PM
MoneypitCJ5
1977 CJ5
If you want to know for sure, turn the crank 180. The distributor should move 90. I'd say if that's not happening you've got a problem.
When you change directions you move the slack side of the chain and it moves more than you'd expect.
