Trying to Crank 76 CJ5 After Rebuild--Help!! - JeepForum.com
post #1 of 3 Old 05-01-2010, 07:57 PM Thread Starter
blackhawk51
1976 CJ5
I'm at the end of the rebuild on a 76 CJ5 and having trouble getting her to start. I totally rewired the Jeep with a Painless kit. THe engine is turning over, I'm getting gas to the carb, the coil, distributor and plugs are all getting fire. But....that darn thing will not crank. I've tried starting fluid and then gas in the carb with no luck.
I'm ready to finish this build and am at my wits end on how to get her to run. Can anyone help?
ΜΟΛΩΝ ΛΑΒΕ
My CJ5 Restore and Build Thread
blackhawk51 is offline
post #2 of 3 Old 05-01-2010, 10:04 PM
rodjr
1980 CJ7
sounds like a timing issue, maybee u got spark but at the wrong time. pull the plugs, put your finger over #1 hole, have somebody turn the engine by hand till u get some compression, then use a long screwdriver on top of piston as u turn by hand to get the piston at aprox top dead center. pull the dist cap the rotor should b pointing at the #1 plug wire terminal, or close to it. if not pull the dist and make it so. then crank, if no go loosen the dist, turn a little, try again. then go the other way if it doesnt fire. the only other thing i can think of would b plug wires mixed up on firing order.
rodjr is offline
post #3 of 3 Old 05-02-2010, 05:52 PM Thread Starter
blackhawk51
1976 CJ5
You nailed it...it was the timing.
ΜΟΛΩΝ ΛΑΒΕ
CJ7 will not crank! hummer6504x4 Jeep CJ Forum 2 04-03-2010 07:12 PM
4.0 crank in a 258???? 78treehugger Jeep CJ Forum 20 11-25-2009 01:56 PM
Bell crank arm rebuild help???? Executioner Jeep CJ Forum 2 07-03-2008 05:23 PM
Won't Crank crrushing Jeep CJ Forum 2 02-16-2008 12:14 AM
Won't Crank?? colby72olds Jeep CJ Forum 21 10-29-2007 11:13 AM
