is it true ? - JeepForum.com
post #1 of 2 Old 07-11-2005, 07:48 PM Thread Starter
sandhog
is it true ?
I have 1980 cj 5 with 327 sbc and 350 trans if I use advdnce adaptor motor mounts and move engine 1 inch to the left that will clear my front drive shaft right now it hits trans oil pan on very right side any help will be grate
sandhog is offline
post #2 of 2 Old 07-11-2005, 08:01 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I run a small block/T350 setup in my CJ too. I feel your pain with the driveshaft. My motor is currently centered but I'm running a long-splined driveshaft with the splined part riding next to the pan. The actual tube doesn't start until a couple inches from the pan. I have made contact under hard flex but normally, the smaller diameter of the splines clears okay...
BESRK is offline
Is it true? 69cj5 Jeep CJ Forum 8 06-03-2007 07:13 PM
Too good to be true? 69 CJ, $500 RickyN29 Jeep CJ Forum 26 07-28-2006 07:12 AM
Could this be true jeepe Jeep CJ Forum 13 11-18-2005 03:24 PM
true jdub_cj Jeep CJ Forum 1 06-10-2004 07:52 AM
is this true? jeepnut00 Jeep CJ Forum 6 03-02-2004 10:51 AM
