Trapshooter's 401 Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Trapshooter's 401 Build
Threaded Fixit Weld Washers!Why yes, we do still offer our Jeep Forum discount--code i2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 03-04-2012, 09:07 PM   #1
Trapshooter
Trapshooter's Avatar
Well its time, the old 258 is burning to much oil and I've put off building the 401 long enough. Like TK Fireman's build, this is going to take a bit of time due the dollar and cents that will be needed to complete the project.
I purchased my core over two years ago and its been sitting in my garage ever since. Today I decided to get after the build.
The PO had already purchase a new Crower cam but at this point I'm not sure I will use it. The part number is 45915. I need to confer with my machine shop to see if this cam will work for my build. I want a low end torquer when I get done with this engine.
I didn't get the original intake and carb as the PO had sold the components to someone else. My plan is to install an Edelbrock intake and Holly Truck Avenger carb so I didn't care about not having the original parts.
After laying out all the pieces it was time to disassemble the remainder of the parts.
Here is a picture of what I have less the valve covers and the oil pan:
I took inventory and started to remove the heads.
All the lifters where easily removed with a pick and I pulled the cam.
Next was to punch out the pistons. I found I didn't have much of a build up at the top of the cylinder walls. A small scrapper took care of carbon.
This engine may have been rebuilt at some point. All the cylinders exhibit some very nice cross hitch. The engine has been painted black but I was of the understanding that the original color was blue. I was told the engine came from a '77 Waggy. The seller still had the body in the back of his property.
I reinstalled the main bearing caps and will take the block to the machine shop I hope by Thursday of this week for cleaning, magnifulx, and inspection.
If the block doesn't pass mustard this project will be over and I will have some parts to sell.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build: http://www.jeepforum.com/forum/f8/tr...build-1338277/
Trapshooter is offline   Reply With Quote
Unread 03-04-2012, 09:11 PM   #2
MoC
Invisible
MoC's Avatar
Fingers crossed for you on the block turning out good!
MoC is offline   Reply With Quote
Unread 03-04-2012, 09:24 PM   #3
Trapshooter
Thanks.....should know by early next week.
Unread 03-04-2012, 11:52 PM   #4
travisrda
what are you putting behind it? I just "finished" putting my 401 in my 84 and i love it! Good luck with your build I'll be following along. hopefully it doesn't take you as long as it did me took me about 3 years or so.
travisrda is offline   Reply With Quote
Unread 03-05-2012, 06:20 AM   #5
TKFireman
TKFireman's Avatar
1980 CJ7
As you mentioned, it took me a while, around a year or so, but it was well worth it. Building an engine was a great learning experience for me and a lot of fun. Mine is a fairly stock build with a simple cam, headers, edelbrock intake and Holley truck avenger, and it'll suck you back in seat when you want it to.
"If your gonna be dumb, you gotta be tough"
Build Thread
TKFireman is offline   Reply With Quote
Unread 03-05-2012, 08:46 AM   #6
Trapshooter
travisrda....I have a T-18 in my '86 CJ7 now and its in great shape. I am hoping to pull the 258 and install the 401 in its place.
Unread 03-05-2012, 08:51 AM   #7
Trapshooter
TK.....I've read your build thread about three times now, in fact I was on the road four days for business last week and read your entire thread again.
Like you my goal is reliability and low end torque with this engine. I will be working with the machine shop to acheive those goals. Ever since I sold my '79 CJ7 with a 304 I've missed having a V8 in my CJ.
Unread 03-05-2012, 10:28 AM   #8
LT1CJ7
1983 CJ7
I'm sure your aware, But do you have any plans for oiling system upgrades ?
LT1CJ7 is offline   Reply With Quote
Unread 03-05-2012, 07:59 PM   #9
Trapshooter
LT......yes I have a copy of BJ's book and printed out the article on the subject that JeepHammer posted the other day.
Unread 03-05-2012, 08:08 PM   #10
RobsCrawlin7
**** it, lets do it
RobsCrawlin7's Avatar
cant wait to do a 401 for mine. i too will be going for reliability and low end torque. i am definitely following this one.
'79 CJ7 PICS HERE specs in profile - SOLD
'01 TJ 4.7/NV3550, 4" lift 33's stroked
'98 Chili Pepper Red XJ Sport, 4.0, AX15, 4x4 3" lift, 31" AT's
'79 CJ7 stock, 304
Originally Posted by my_304_cj7 View Post
I used Marvel once before I took my Jeep out on the trails. I didn't get stuck all weekend so I guess it works.
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline   Reply With Quote
Unread 03-09-2012, 08:09 PM   #11
Trapshooter
Well got the block to the machine shop today. I should have the results from the magneflux by Tuesday or Wednesday of next week.
I know these pictures don't look like much but here's the block on the tail gate on my Avalanche.
I also started cleaning up the front cover this afternoon. I pulled the water pump off the cover as well as the oil pump housing. After cleaning the oil off the gears I found a nick, I was not happy. The pick is pointing at the damaged tooth. I'm thinking this may be cause for replacement. I'm open to any thoughts and feedback.
Tomorrow I get to use my new, at least to me, valve spring compressor. Picked this up at the local rental shop that is liquidating all their automotive tools.
I'll get some pics up on the heads after I pull the valves.
Unread 03-10-2012, 08:11 PM   #12
Trapshooter
Well got to use the new valve spring compressor today, it worked great. Removed all the valves from both heads and found a couple of interesting items.
Valve seats all looked good except one exhaust port that must of received a dose of coolant when the engine was removed.
Everyone of the intake valves had a build up similar to this unit.
About 50% of the valve stem seals had some type of chunk missing and all of them where brittle and hard.
The most interesting discovery of the day was the pistons. I cleaned the crown of a couple of them and found .030 stamped on the dome.
I figured the engine had been rebuilt or at least repainted at some point since the block was painted black. So the block has been bored 30 over.
I measured the crankshaft mains and rod journals and found them to be at the standard dimensions. So, the crank was not been turned.
With the condition of the valve stem seals, I would guess the heads have not had any work done to them as well.
I really will not know until I get all these pieces into the machine shop and let the pros check it out.
Unread 03-10-2012, 08:39 PM   #13
TKFireman
TKFireman's Avatar
1980 CJ7
A lot of your pictures look very familiar.... looks about the same as my 401 when I tore it down, just without the .030 on the pistons. Hopefully you'll get lucky and it won't need to be bored any more which will save you some. Are you planning to go with a higher compression piston or stock?
Build Thread
Unread 03-10-2012, 09:03 PM   #14
Trapshooter
I'd like to go with the pistons I already have, if for no other reason than to save some coin.
I really have no desire to build a high compression engine, regular unleaded is spendy enough. I'd hate to think my new engine would only run on high octane.
I will know more by the middle of next week after the machine shop has a chance to clean and measure the block if I'll be able to reuse the existing pistons.
I was happy to find the crank had not been turned.
Tk....what are your thoughts about the ding in the oil pump gear? I was pricing some rebuild kits today and think I should just put in new. They were not that expensive.
Unread 03-10-2012, 10:17 PM   #15
TKFireman
TKFireman's Avatar
1980 CJ7
My engine rebuild kit came with new pump gears, so i would wait to see if your engine rebuild kit includes them before ordering some. Replace them either way. The bigger concern is what does the inside of your oil pump housing look like? Jeephammer goes over checking the clearances of the oil pump in a thread that is linked in his signature, I highly recommend doing that. If there are groves inside the housing, that will hurt your oil pressure. Bulltear sells a steel endplate that keeps the gears from scoring the aluminum pump cover, but there is nothing you can do if the sidewalls of the housing are scored.
Build Thread
