Transmissions - JeepForum.com
post #1 of 9 Old 12-18-2009, 07:44 PM Thread Starter
TKFireman
1980 CJ7
Transmissions
I would like to upgrade my t176 to a Manuel tranny with overdrive behind my 304. Obviously a NV4500 would be sweet, but a ton of money, and a ton of money in adapters. I was looking at either a AX-15 or a NV3550, there are a couple of wranglers at the local pick and pull with 5 speeds. Jeep will be mostly driven on road, but want it to be capable off road as well.
1. I think the 2000+ ones are NV3550's and pre-2000 is AX-15, is this correct? There are some of each at the lot. The NV3550 has a lower first gear, the AX-15 would possibly be a little easier/cheaper to adapt. I'm leaning toward the NV3550
2. Any other suggestions?
3. What kind of function check can be performed at the lot before I bring one of these home? These were all clunkers, so they were driven onto the car lot, but I'd like to be able to do a simple function check.
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #2 of 9 Old 12-27-2009, 01:41 AM
SST4530
1979 CJ5
I would check out Novak adapters and read about the differrent tranny swaps. great site for info.
1979 CJ 5 4.2 / T150 3 spd / Dana 20 T-case / 4" lift / 33x13.5-16 Swamper LTB's
SST4530 is offline
post #3 of 9 Old 12-27-2009, 05:57 AM
Mike Romain
With 35" tires and 4.11 gears you won't likely be able to use an overdrive. The RPM will be too low which will lug the engine and just drink gas.
Mike
Mike Romain is offline
post #4 of 9 Old 12-27-2009, 03:13 PM
rustymudder
1982 CJ7
this is from novak's site:
No additional input shaft is typically required for:
AX15, 1988-1999
AW4, 1991-1999
If you are unsure about which to choose, follow this rule:
If you have a 23 spline transmission output shaft whose end extends ~1/2" past the rear face of the transmission flange, you do not need a new input shaft.
If you get that AX15 then all you need is the adapter which is $123 from novak to adapt it to the dana 300.
I highly recommend novak, I got my T18-dana 300 adapter from them and they were very helpful, great service.
rustymudder is offline
post #5 of 9 Old 12-27-2009, 09:17 PM Thread Starter
TKFireman
1980 CJ7
Lots of flat highways around here with a 70 mph speed limit, all the way from here to the beach, think the 5 speed would definitely come in handy there. 65 at around 2150 rpm, 75 at around 2300 rpm for the AX-15. That sounds better than the 65 at 2550 rpm and 75 at 2950 rpm I have now with a T176. Am I missing something, where is the power range in rpms for a stock 304? what rpm range gives the best MPG?
(RPM numbers calculated here Gear Ratio Calculator)
Anyone know if I got the AX-15, would the drive shafts work as well, seems the ax-15 is about 3" to 4" longer than my T176, then a little more for clocking ring for D300. Will the drive shafts from a mid 90's wrangler work, or can I plan on new custom drive shafts too?
post #6 of 9 Old 01-03-2010, 08:01 PM
Boxcar
1974 CJ5
If your 304 is bone stock you should be ok for a wile but if you have upgraded it at all an ax15 is a poor choice in trannys at best. Yes you will need new drive lines both front and rear. You may be able to use yj shafts but I am not sure. I would do a bit more resurch before you invest any $ into an ax15 to v8 swap....Boxcar
Boxcar is offline
post #7 of 9 Old 01-03-2010, 08:07 PM
NEPAjeep02
NEPAjeep02's Avatar
Look into the Ford NP435. From what i've been told it is a bolt on. It has a granny low 6.69:1 ratio. Can't go wrong with that.
2002 Jeep TJ X - See sig
1974 Dodge Powerwagon W200 (Beater)- D44 front(4.10), D60 rear(4.10), 318 V8, NP435, NP205 NP203 Doubler. STOLEN
1980 CJ-5 - Parting out. Let me know if you need anything.
1983 VW Rabbit GTI - 2.0 ABA swap, etc.
1998 VW Jetta GT - Parts car
NEPAjeep02 is offline
post #8 of 9 Old 01-04-2010, 07:48 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I think 2300@75 is going to be a bit low. The wind resistance on your CJ doubles between 55 and 70. This requires more RPM's to overcome. I would be hesitant to drop below 2500 at that speed (not that I advocate driving 75 in a CJ).
jeepdaddy2000 is offline
post #9 of 9 Old 01-04-2010, 08:24 AM
twmattox
I disagree. My Scrambler has a T-5, 3.31 ratio axles, and 31" tires. I turn around 1800 RPM at 65-70mph. It does just fine on flat areas. If I encounter a long uphill climb, or headwind (or both) I just downshift. I get exceptional mileage too (consistently 18-20).
twmattox is offline
T18 Transmissions and V8's Mattaeus Jeep CJ Forum 23 04-06-2011 09:39 PM
258 79 CJ7 Transmissions imacrazyguy2 Jeep CJ Forum 4 06-09-2009 09:11 AM
Switching transmissions BeesJeep Jeep CJ Forum 3 05-12-2007 11:19 AM
Transmissions jeffs77CJ5 Jeep CJ Forum 3 06-26-2003 04:25 AM
know anything about transmissions? GRLSCAN2 Jeep CJ Forum 7 06-06-2002 04:20 PM
