transmission torque bushings - JeepForum.com
post #1 of 6 Old 03-17-2003, 12:23 AM Thread Starter
rustyCJ
just how do these go? i thought there was all kinds of wobble in the stud because the bushings were shot. i got my new bushings today and they will be the same way. maybe i am trying to stick the tranny torque stud back on wrong or something, i dunno. the stud goes through the big hole, one bushing on bottom and one on top with the nut on top tigthening as far as the smaller holed washer will let it, and the lower stud going through the hole in the skid plate?
i gonna feel stupid if that isnt right, if it is then i dont get it. i will have a 1/16" of an inch between the bushings themselves and about 3/4" between the flanged part on them. they dont clamp down on or hold anything.
anyone understand what im trying to ask? anyone have a pic or something?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #2 of 6 Old 03-17-2003, 06:17 AM
pontiac58
1980 CJ7
Your not losing your mind. Ever one i have ever seen is loose. Not sure why, even the factory one that was on mine was loose. The fix is add a few shims to tighten it up. I think i used two 1/2 washers on top of the skid plate to tighten it up. I may have used others at different spots, but i dont think i did.
pontiac58 is offline
post #3 of 6 Old 03-17-2003, 08:46 PM
goody350s
i put a new one in also
couldnt figure out why it was loose
either,my best friend(bartcj5)who
is helping me rebuild my jeep
brought his over and his is loose also
but it was bugging the hell out of me
so i put some washers under the new bottom
poly bushing to tighten it up a bit
anyway hpe this helps
if you find out anything else please let
us know
75 jeep cj5 project
goody350s is offline
post #4 of 6 Old 03-17-2003, 11:37 PM
blackdog
Both previous posts are correct. I just
replaced the transmission mount and
the torque arm bushing in my 85 CJ7 and
had to add several washers to shim it
correctly. It should be snug and
not be loose in either direction. If it's
not, it will cause the clutch to "skip", at
least that's what it feels like, when you
start from a stop. This seem to be
a common problem and why they don't
make the poly bushings so where you
don't have to shim them is anyone's
guess.
Hope this helps. If you want, I have
a picture of the shimmed bushing that
I can email to you. If I could figure out
how to post a picture here I would, but
I don't, so shoot me an email if you're
interested.
Mike
85 CJ7
blackdog is offline
post #5 of 6 Old 03-18-2003, 04:16 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I am just to do this on my 5, so I am sure it is similar. I would love an email with a pic, thanks.
Thanks,
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #6 of 6 Old 03-18-2003, 08:11 AM
twmattox
I was working on my t-case this winter and snapped my tranny stud when removing the skid plate. I replaced with a grade 8 bolt and the remnant bushing from an old set of shocks (Sunday evening fix so I could drive home from my friends). I snugged everything down tight and seemed to function well. However, I noticed one monster of a squeek when sitting at a stop and idle. When I loosened the temp stud up to allow a little room, squeek went away. The slop could be to cut down on squeeks and other noises...
twmattox is offline
Transmission Torque Arm kjhibbs Jeep CJ Forum 5 10-24-2009 09:33 PM
Lift kit bushings/ Body bushings, This is confusing me!! FLBOY Jeep CJ Forum 5 04-03-2009 09:13 AM
To Torque Or Not To Torque...That Is The Question 79BlackPearl Jeep CJ Forum 8 06-02-2008 11:10 AM
Transmission or Torque converter? dirtbagofva Jeep CJ Forum 2 06-26-2007 09:10 AM
Torque setting for body bushings BIGM Jeep CJ Forum 2 03-13-2006 06:05 AM
