Transmission Skid Plate Bolt Sizes - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Transmission Skid Plate Bolt Sizes
End of Summer Sale, 20% OFF!2007 - 2011 Jeep JK Long Arm Lift KitsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-12-2014, 09:42 PM   #1
VaCJ79
1979 CJ7
I was going to replace my transmission mount but after soaking the bolts I already have snapped two. So I need to get a drill bit and tap. From what I found the bolts should be 3/8 - 16. Is this correct?
Thanks
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline   Reply With Quote
Unread 09-12-2014, 09:53 PM   #2
Tollster
1980 CJ5
Thanks
If you have them out, get a tap, and lay the tap threads along the threads of the old bolt... if it fits, its the one... its the only way I have ever done it..
Tollster is offline   Reply With Quote
Unread 09-12-2014, 09:57 PM   #3
Mortgage-payer
Junior Member
1976 CJ7
Mine were 3/8-16 x 3/4 flange head.
3 on each side into the frame.
Mortgage-payer is offline   Reply With Quote
Unread 09-12-2014, 11:30 PM   #4
tombstne
1982 CJ7
For my stripped threads, I used http://www.timesert.com/
The kit was a bit pricey though
tombstne is offline   Reply With Quote
Unread 09-13-2014, 08:05 AM   #5
VaCJ79
1979 CJ7
Thanks, I just wanted to make sure.
Unread 09-13-2014, 11:49 AM   #6
Dborns
1983 CJ7
I had two of the skid plate bolts break on me also. Instead of redrilling and tapping a new hole, I hit the broken end of the bolt which broke the nut welded on the inside of the frame loose leaving a nice clean hole. Luckily, the two holes were in a spot where I could just barely get to them from another access hole on the frame. I then taped a new nut/ washer into the head of a wrench, fished it into the frame, and ran a bolt up into it. The tape held the nut/ washer in place in the wrench while I tightened the bolt down.
Not saying that's the best way to do it, but it worked for me.
Dborns is offline   Reply With Quote
Unread 09-13-2014, 02:01 PM   #7
82JeepCJ7
1982 CJ7
Make sure when you put the new bolts in, you use anti-seize on them...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote
Unread 09-13-2014, 04:40 PM   #8
LumpyGrits
If stripped-Just retap to 7/16 bolt.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 09-14-2014, 02:34 PM   #9
VaCJ79
1979 CJ7
good tip, I use anti-seize where ever I can.
ripped the heads right off after a 1/4 turn but Ill keep that in mind.
