Transmission Problems - JeepForum.com
post #1 of 5 Old 08-20-2013, 07:06 PM Thread Starter
twmorgan
1957 CJ5
I have a almost stalk 1957 CJ5 it has a T90 3 Speed transmission. Yesterday I put it into revers to pull out of a parking spot. When I let the clutch out it really bogged down the engine. when i out the clutch back in it would make a bit of a slight grinding noise and come to a complete stop almost immediately. In gears 1-3 there seams to be a bit of a grind but not as much as revers. It shifts through the gears as normal only makes the grinding noise when the clutch is in and when in revers.
I am thinking Clutch or throwout bearing. Any thoughts, am I on the right track?
Thanks
Travis
1957 CJ5
twmorgan is offline
post #2 of 5 Old 08-20-2013, 08:05 PM
LumpyGrits
Sounds more like you broken some springs in the clutch's p'plate.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 5 Old 08-20-2013, 09:08 PM Thread Starter
twmorgan
1957 CJ5
Could springs cause it to be worse in revers?
Travis
1957 CJ5
twmorgan is offline
post #4 of 5 Old 08-20-2013, 09:20 PM
LumpyGrits
Yes, reverse has no syncro.
It could also be a T/O bearing or release fork issue.
Check your linkage for damage too.
LG
post #5 of 5 Old 08-20-2013, 10:59 PM Thread Starter
twmorgan
1957 CJ5
Ok this gives me a good place to start in the morning
Thanks
Travis
1957 CJ5
twmorgan is offline
