transmission problems - JeepForum.com
post #1 of 11 Old 03-26-2013, 07:59 PM Thread Starter
NEKamc14
hey guys new to the web site and first post so here it goes. I was driving home from school today in my 1985 cj 7 when i started coming up a hill when all of a sudden my jeep comes to a hard stop and dies. pushed in the clutch and the jeep didnt move. started it back up and brought the rpm s up and dropped the clutch didn't move did it again and got it to budge only a bit so when i pushed the clutch in it rolled down the hill and out of the middle of the road. when it wasnt moving my shifter was stuck in first now its out but tranny does sound good when pulled home wont go in gear just grinds
any suggestion ??
BTW tranny s a t4
NEKamc14 is offline
post #2 of 11 Old 03-26-2013, 09:14 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by NEKamc14 View Post
any suggestion ??
BTW tranny s a t4
Welcome to the forum!
I'll take a stab at this. You might try putting the transfer case in neutral and seeing if the problem is the same. If it is, then that points to the transmission as the problem. If the transfer case is in neutral and the problem goes away, then maybe the problem was downstream of the transmission (ie: transfer case, drive shafts, axles). It's a quick test to try.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #3 of 11 Old 03-26-2013, 09:24 PM
82JeepCJ7
1982 CJ7
Operation boat anchor...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 11 Old 03-26-2013, 09:36 PM
BagusJeep
1981 CJ7
Could be your clutch.
When you have it in neutral at the transfer box see if you can work through the box without the engine on. With the engine at idle you should be able to force it into gear with the transfer box in neutral without a clutch.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 11 Old 03-26-2013, 09:37 PM
caseypotts
1980 CJ7
Hydraulic clutch?
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #6 of 11 Old 03-26-2013, 10:23 PM
jeep1000
I have an '85 CJ7 as well. This sounds a lot like a clutch issue. As stated above, try neutral in the Transfer Case and if it goes away, look south if the tranny.
Jonathan
'86 CJ7, I6 258 four speed manual. See ya on the trails!
jeep1000 is offline
post #7 of 11 Old 03-27-2013, 07:15 AM
mastercraftka
mastercraftka's Avatar
Yes I would look at clutch first I had my linkage jump off one time.
1984 CJ 7
1948 CJ 2A
1982 CJ 7
1981 CJ 7
mastercraftka is offline
post #8 of 11 Old 03-27-2013, 11:10 AM
79jeepincj7
1979 CJ7
It wouldnt have stopped your jeep tho if it was the clutch.. the jeep is old enough that you can put it in first and just start it and it will start up and go if the trans is okay. The T4 is a pile to begin with also.. I'd bet your trans needs to be replaced. It wouldnt have ground on the way home either if it was just a clutch.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #9 of 11 Old 03-27-2013, 11:14 AM
82JeepCJ7
1982 CJ7
There was a recall on the T4 and T5 years ago from them locking up while driving.
Vehicle 1982 JEEP CJ7
Manufacturer CHRYSLER CORPORATION
Manufactured between 4/1/1981 - 3/1/1982
Recalled on 12/17/1982
Influenced by CHRYSLER CORPORATION
Owners Notified on 1/27/1983
# Affected 13,532
Recalled for POWER TRAIN:MANUAL TRANSMISSION:LUBRICANT
Description ORIGINAL PRODUCTION TRANSMISSION LUBRICANT USED IN THE INVOLVED VEHICLES MAY NOT PROVIDE ADEQUATE LUBRICATION TO PROTECT THE TRANSMISSION"S FIRST GEAR.
Consequences
Corrective action THE DEALER WILL REPLACE THE ORIGINAL PRODUCTION LUBRICANT AT NO CHARGE TO THE OWNER.
Notes VEHICLE DESCRIPTION: MULTIPURPOSE PASSENGER VEHICLES AND TRUCKS EQUIPPED WITHT4 AND T5 MANUAL TRANSMISSIONS.SYSTEM: POWER TRAIN; MANUAL TRANSMISSION, LUBRICANT.CONSEQUENCES OF DEFECT: IN EXTREME CASES THE TRANSMISSION COULD FAIL TO OPERATE DUE TO LACK OF LUBRICATION. THIS FAILURE COULD OCCUR WITHOUT PRIOR WARNING AND MAY CAUSE A VEHICLE ACCIDENT.NOTE: PRIOR TO SERVICING, OWNER IS ADVISED TO AVOID DRIVING AT HIGHWAY SPEEDS.ON VEHICLES EQUIPPED WITH 5-SPEED TRANSMISSION, AVOID USING THE FIFTH GEAR.
post #10 of 11 Old 03-28-2013, 06:57 PM
nekamc
Thanks guys I didn't like that last post to much cause I took the t5 and Dana 300 out of my 1982 amc eagle. Fixed the problem runs great now. If this tranny does goes to I'm goin to have to buy a reverse for the t176 which was originally was in the jeep.
nekamc is offline
post #11 of 11 Old 03-28-2013, 07:01 PM
nekamc
82jeep cj 7 you hit it right on the nail. Thanks for the head up for the tranny in it now
nekamc is offline
