Transmission Problem 1982 CJ-7 - JeepForum.com
post #1 of 6 Old 05-01-2008, 10:46 AM Thread Starter
stelo
1982 CJ7
Dear Members I have just purchased a 82 CJ 7 I has been parked for approx. 1 year and now the it will not do anything in reverse but drives fine forward thru all gears!!!! Does anyone have a idea of what could be wrong with the reverse ??? It is a automatic transmission.
So someone please reply I am lost in this transmission matter and I am a new jeep man...and owner...
Thanks Stelo
stelo is offline
post #2 of 6 Old 05-01-2008, 03:11 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
First, get your wallet ready
No, it will be interesting to see what people have to say on this. But I can't imagine a problem like that with an automatic transmission would be fixed for cheap.
You could check the fluid level, but I doubt this has anything to do with the problem.
Ken4444 is offline
post #3 of 6 Old 05-01-2008, 03:27 PM
Mike Romain
Low fluid will kill or drop out reverse first, then the rest of it 'really' fast.
Mike
Mike Romain is offline
post #4 of 6 Old 05-01-2008, 04:27 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
That's great news. Maybe the problem can be fixed with a bottle or two of ATF.
Ken4444 is offline
post #5 of 6 Old 05-01-2008, 05:08 PM
Mike Romain
It's possible. They are tough, I have seen buckets of mud come out of them and they still worked after fresh fluid.
Mike
post #6 of 6 Old 05-01-2008, 08:12 PM
JeepHammer
Running On Empty...
1973 CJ5
Thanks Stelo
Do you know WHICH automatic you have, Chrysler TF999 or GM's TH-400?
If it's the TH-400, I know EXACTLY what it is,
The center support busing is worn out and has let the direct drum drop down on the seals on the center support snout.
Not hateful expensive to fix (if you do it yourself) and not hard to fix if you can do an automatic trans without going into convulsions (most people can't)
If it's the Chrysler TF999, it's more than likely the band is out of adjustment or the servo seals have given up...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
4.2 only in 1982? budacj7 Jeep CJ Forum 3 01-29-2010 04:42 PM
1982 Cj7 dawgs30814 Jeep CJ Forum 3 01-20-2010 07:32 AM
1982 CJ - what do you think? TJTony Jeep CJ Forum 2 07-17-2007 08:34 PM
1982 CJ7 4.2L and transmission question ademster Jeep CJ Forum 1 09-13-2006 08:25 AM
1982 CJ7 with 258 cid and A/C ghandyman Jeep CJ Forum 3 12-20-2005 08:16 PM
